Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
My desktop is failing to load,power is coming nothing on monitor.
Power is coming on, the funs are runing,cd rom and flopy lights showing but no processing.
  • 643 Answers
Do u mean that the monitor is dark, and LED on monitor is blinking?
IF yes, then probably display problem...
If using graphic card, just switch to built in display...
If this cannot, u can try clear CMOS...
Posted on Feb 13, 2009
My cd-rom on dell Dimension 8250 pc desktop computer will not show up on my computer. Am i missing cd-rom drivers.
hello,
1.first go to http://support.microsoft.com/mats/cd_dvd_drive_problems
click on the green button that has run now
Run the microsft fix it tool
if it works GREAT! if not go to #2
#2 go to this site http://www.techsupportall.com/fixed-solved-cd-drive-not-found-not-detect-remove-upper-and-lower-filter/
follow instructions
IF THAT WORKS GREAT! if not proceed to 3
#3 turn off computer unplug power cord.
open your computer case unplug the cables that connect to the back of the cd rom. plug computer back in power it up. shut it down once it loads. then once it is powered down open case again and plug the cables back in make sure they are connected well. close case and power up the computer.
hope that helps
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
I have Accer Mini tower with dou core 3.0 processor i remove the cpu fun with the heat sink to add oil to the fun and a return back properly i didn't touch any thing but after i turned on it , the fans...
Hi
Before your computer running fine, you just remove the fan and heat sink, and fix properly.
1) Check your VGA cable both of side fix properly
2) Check your Monitor power button is switch on.
3) Remove your RAM and fix again.
May you fix your problem
Jun 01, 2011 | Acer Veriton M460 Micro Tower Core 2 DUO...
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
My compaq evo d51s is not displaying on the monitor at boot up.
Cleare Bios and replace the RAm if not solved use pci vga card, cirus logic or sis 6326 AGPcard
Nov 02, 2009 | HP Compaq EVO D51S Intel Desktop PC -...
Our hp pavilion 4535 will not read discs
I'm thinking of a couple of solutions:
  1. Auto run as turned off, navigate to your drives (usually in the My Computer icon) and check for your disc drive (usually Drive D:). If it is showing a disc then you can right-click and open to see the contents or double click for an auto-play.
  2. If you open up the drives and don't see a CD ROM drive then it might have gotten dropped some how. In this case you will want to go to the device manager and check to see if the CD ROM drive is listed and if it needs some fixing.
Mar 13, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Upgrading Motherboard
mother board power is coming prosser fan is runing but display is not coming plz solution
Mar 05, 2009 | Intel DG31PR Motherboard
Computer boot but nothing show up on monitor
nothing, the computer just restart itself then at first nothing show up and no beep the keyboard has no power sound but i can open close the cd rom,now it boot up but with cmos error and the ddr speed get lwer from 333 to 266 and it boot just up to the boot from cd press any key part and then it hangs it did'nt boot the window xp
Jan 11, 2009 | Computers & Internet
Fans and lights come on but the harddrive and cd bays do nothing
If you replaced the power supply did you plug it into the drives. If so then your motherboard is most likely faulty.
Oct 08, 2008 | E-Machines eMachines Desktop PC
DVD NOT SHOWING
hi frined
change ur data cable & power cable & try to ditecing
if not show then do one ting go in a device manager >system devices>pci bus>right click on it & uninstall then ur pc is restarts
& insatll ur all divce drivers correctly
thnx using fixya
Apr 01, 2008 | LG (CRD-8400CB) CD-ROM Drive
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
116 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
