Question about Toshiba 50H81 50" Rear Projection Television
No picture- red light is on steady(not flashing like other posts)
My 50H81 Toshiba is 7 years old and has never given me any problems till now. It is used on average 6-8 hours a day. I used it for about 2 hours and shut it off for about 10 minutes. When I turned it back on the screen was black. The power light was on steady(no blinking) and it made the normal start up sound. I tried unplugging it and that didn't work. I shut it off for 1.5 - 2 hours and tried it again and it started up fine. Should I start shopping for a replacement or is this economically fixable?
  • dreykdal2 Feb 13, 2009
    Thank you freetek. I'll give that a try.
  • Toshiba Master
  • 5,568 Answers
Your good description of events is helpful and points to the power supply as the culprit. This is probably on a separate board (they are often out-sourced) and may be easy to replace. You should be able to identify the board since it will be smaller than the main board and have larger components on it including one or more transformers and larger capacitors (plastic shrink-wrapped cans of different sizes).
If you want some confidence before rushing out to buy one or have this one repaired, you could pick up a can of 'freeze spray' from any electronics supplier (Radio Shack may have it too), pull your set from the wall, loosen the screws on the access panel behind (don't remove it; that may improve cooling and mask the failure), keep the freeze spray handy so if it fails, you can pull the panel and start spraying the PS board. I'd start with the small to medium sized capacitors since these are often at fault once aged.
Good luck-
Posted on Feb 13, 2009
  • Steve Allison
    Steve Allison Feb 13, 2009
    I failed to mention that if the set is still under power, be very cautious where you put your fingers; the power supply may have several hundred volts applied to areas that can be inadvertently touched.
How to fix red & blue lines to align, box 3,7.8 on 50H81?
Have to do convergence adjustments; provided the circuit part to convergence section works properly. Check it out first.
If it works properly, do a convergence adjustment. Do it carefully. Before start to do it, read and understand all the steps have to do.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Details about this adjustments have given by one of the posts.
Aug 23, 2014 | Toshiba 50H81 50" Rear Projection...
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Red power light flashing; will not turn on.
It is very likely that one of the convergence correction chips has gone south on you (either that or a capacitor). What you want to look for is a swollen capacitor , or a burnt resistor near the two large heatsinks on the signal/convergence PCB. The flashing LED is an indication that the power supply has detected a fault, your mission is to determine what that might be. another thing to check out at the fuses on the power supply PCB (these have labels like FXXX were XXX is a number). If you find an open fuse, that will help determine where to look for the fault.
Jun 18, 2009 | Toshiba 50H81 50" Rear Projection...
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
Red light flashes no picture or sound. Likely causes?
did your TV just cut off in the middle of watching it and it want come back on. My red light beside the power button flashes also.
May 06, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 Has Power but No picture or Audio
ok i'm goin to need more info about your problem. you stated fuses and didn't say the location numbers of the fuses. Also, have you rechecked your fuses to see if they are all still good? 3 fuses sounds like more then one problem. once you tell us your loc#'s of your fuses, we can look into your problems.
Apr 07, 2008 | Toshiba 50H81 50" Rear Projection...
Tv won't come on
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the ned and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
Open back cover, 9 screws and wirings (pls mark), removed(soldered) a electronic board infront of convergence ic. removed IC (stk392-110) (screwed and soldered).
Replaced everything and voila...! it is now working again..
no more shutsdown and red blinking light. Saves mo $400 for a repariman. of course just be careful with static and stuff.
Feb 29, 2008 | Toshiba 50H81 50" Rear Projection...
5 year old tv
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the net and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
I don't know how to solder, so I ask friend to do it for me. But I did the rest. Just to give you an idea that it can be done even if you don't know much about electronics. This in no way a recommendation but just stating my experience. Follow at own risk.
Feb 16, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81
most commom problem is convergance ic gone bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 08, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 Re Blinking Light...wont work
best advice is go get a manual book on how to fix tv
May 07, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
170 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
