Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
Water in bottom of fridge
I think my drain tube is clogged on my whirlpool et18pk can you tell me how to locate the tube so that I can clean it?
    President:
  • 1,902 Answers
In the back of the fridge way down low on the very bottom you will see the tube. If you think it is clogged. Take a spray bottle filled with very hot water and just a cap full of bleach. Spray it on the drain hole and this will rsolve your blockage issue
Posted on Feb 13, 2009
My whirlpool side by side Why is my whirlpool side by side refrigerator model ED2PHEEMQ00 leaking water out the door or the freezer side.
90 percent sure drain is clogged. when unit defrosts , water from said melting ice is drained away via drain hole and tube to underneaththe fridge. locate drain hole in bottom rear of freezer and pour hot water with turkey baster into hole until it runs out freely
Aug 31, 2014 | Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
Hope this helpout.......
Jul 29, 2010 | Refrigerators
WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
Whirlpool Refrigerator Model # ET21PKXGN00
HI thanks for your question. the problem is with the drain tube, from freezer to the drain pan ,located at the back, by the compressor. to repair. turn fridge off, for 24 hrs. pull fridge away from the wall. clean all the coils. locate the drain tube, by the drain tray. get a small plastic hose, shove the plastic hose up the drain tube. and blow, to dislodge any debris clean the tube thanks the appliance doc.
Oct 15, 2008 | Whirlpool Refrigerators
Water Leaking
HI thanks for your question. the drain tube in the freezer is clogged, not allowing the defrost water to go down to the drain tray. to repair. turn fridge off , for 24 hrs. remove back panel from fridge clean all coils. locate the drain tube by the drain tray. use a small hose to shove up the drain tube And blow , to clear the debris from the drain tube. thanks the appliance doc. please rate my answer. thanks
Oct 14, 2008 | Frigidaire FRS26R4C Side by Side...
Lots of water in side fridge cannot reach lower pan gets past seal on to floor
hi thanks for the question the drain tube is clogged up pull fridge from wall remove back panel if any locate drain tube in the drain tray clean replace .try that thanks the appliance doc
Sep 28, 2008 | Whirlpool Refrigerators
We have ice in feezer and water dripping into refrigerator section. I think the drainage tube is cloged. How do I access and fix problem?
hi thanks for the question yes the drain tube is clogged . turn power off pull fridge from wall clean all coils locate drain tube in the drain tray let fridge thaw with doors open once thawed clean drain tube thanks the appliance doc
Refrigerator
The problem you describe is common but without knowing the make/model I can only answer in broad terms. Water in the fridge section is almost always caused by a clogged defrost drain. Service is different depending on the mfgs but commonly the drain gets clogged by ice or some foreign object. For ice jams, on brands like GE or Whirlpool a "heat transfer device" is available which clamps on the heater and extends into the drain, providing extra heat to allow drainage without refreezing. For solid items, blowing back on the end of the drain hose in the drain at the bottom with compressed air works wonders.
Dec 30, 2007 | Refrigerators
Refrigerators Logo
451 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
