Question about HP 17bII+ Calculator
HP 17BII calculator beeps but won't turn on
My HP 17BII calculator will not turn on. When I press the ON button it emits a high-pitched beep (sound continues for as long as I hold down the ON button). Nothing happens when I press any other button.
  • 118 Answers
SOURCE: HP Compaq dc5000
Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
Posted on Feb 06, 2008
  • 667 Answers
SOURCE: HP 32 won't work
Hey Dave- take a look at the following link. I like to have the user actually look at the user guide instead of describing it. If this solves your problem PLEASE rate this as fixed. If this isn't exactly right or you need more help just add a comment and I'll be glad to help you further. Thanks.
Posted on Apr 30, 2008
  • 2110 Answers
SOURCE: Addition Problem with HP 17BII
do a self test
1. Turn the calculator on.
2. If you have the optional infrared printer, turn it on. Certain diagnostic
information is printed during the test.
3. If possible, return to the MAIN menu (press @A).
4. To start the self-test, hold down C while you press the fifth menu
key from the left. Once the self-test has begun, do not press any keys
until you are ready to halt the test.
5. During the test, the calculator beeps periodically and displays various
patterns and characters. Watch for one of two messages that are
displayed before the test automatically repeats:
􀂄 If the calculator passes the self-test, the calculator displays
􀂄 If the calculator displays     followed by a five-digit number,
the calculator requires service.
6. To halt the self-test, hold down C while you press the third menu
key from the left. The calculator displays             . If you
press any other key instead, the test halts and the calculator displays
a     message. This results from an incorrect key being pressed,
and does not mean that the calculator requires service.
7. If the calculator failed the self-test, repeat steps 4 through 6 to verify
the results. If you do not have a printer, write down the messages that
are displayed in step 5.
Posted on Jan 01, 2009
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Posted on Jan 19, 2009
  • 32281 Answers
SOURCE: HP notepad - continueous beeping sound with equal sign characters
If you are getting a lot of = character along with the beeping, this indicates you have a stuck = key and the beeping sound is the keyboard buffer is swamped with the = character. If you can't unstick this key, then you need to replace the keyboard.
Posted on Jun 09, 2009
Hp altec lansing makes a beeping sound while starting
Try running a registry cleaning program. That should sort the errors out
May 20, 2014 | Acer Computers & Internet
Where is the CPT key on the HPb11 Financial calculator?
There isn't one. Unlike calculators from other makers, the 17bII knows whether you've just input a number or not. Simply press the desired item without entering a number to calculate it.
For example, if the book says to press CPT then PMT to compute the payment, simply press the PMT key on the 17bII.
Sep 07, 2013 | HP 10bII Calculator
Mercury PI865D7 Motherboard system is won't turn on. I Checked SMPS and RAM. it's also a good then what's the problem for this....And Coming high pitched Bee Sound Repeatedly.....
Hello the manual can be downloaded here:
Check the ram modules, and the graphic card.
How many beeps comes, when you start the pc ??
Here is a list of beep codes:
One long beep is a ram module failing.
Try insert one module, and reboot.
The problem could also be, the power supply.
Here is a fault finder guide:
Best of luck
Jan 23, 2013 | Computers & Internet
RCA ctc195 series won't power on constant small beeping sound
if its a high pitched squeek its a short in the deflection circuit, a common failure part here was the high voltage transformer.
Dec 11, 2012 | Televison & Video
Laptop power cord reset
the surge protector that is sometimes included in the power supplies for laptops will emit sound when they have failed. it is also possible that there is a building power fault (ground not connected).
what model is the adapter? it would help a lot. also, which laptop is it?
Feb 17, 2012 | HP Computers & Internet
I can't change the language in HP 17bII calculator
Press SHIFT [MODES]. Press the [INTL] softkey, then press the softkey for the desired language.
Jan 30, 2011 | HP 17bII Calculator
Hp pavilion723a when starts emits high pitch beeps and wont boot
These beeps are telling you that there is something wrong with the hardware. It means something has failed and will most likely need replaising. The certain amount of beeps will tell you the exact piece of hardware, count of beeps and phone hp and they should tell you whats wrong with it and if its repairable.
Good Luck
Aug 28, 2009 | HP Computers & Internet
How do you switch off the sound
For my casio calculator watch (mod no. 437438), I go into the calculator mode and press the button below the one that pops out at the side (don't know the correct term for it sorry). Pressing that button will mute the sounds of your watch, if you want to retrieve the sound, do the same thing again.
Mar 28, 2008 | Watches
HP 17bII+ Calculator Logo
286 people viewed this question
Ben Johnson
