Question about Dometic RM2652 Refrigerator
My dometic frig will not work no power. Has 12 volt and 110 volts
My Dometic frig was in storage and I attempted to turn it on and there is no lights at all come on. Has 12 volt and 110 volts. I think the model number is 3232.
  • Anonymous Feb 16, 2009
    I just replaced my cooling unit and it works great on propane and 110V but not 12V. We have 12v going to the unit but no action, any thoughts?
    President:
  • 1,902 Answers
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
Posted on Feb 13, 2009
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
110 power, no circuit board lighting why is it not lighting?
check to see if 12 volts at unit that runs unit 110 volt for heater element
May 22, 2014 | Dometic RM2193 Compact Refrigerator With...
Dometic rm 2353
pull off back panel make sure 12 volts and check fusible links
Apr 11, 2014 | Dometic Refrigerators
Does not cool on gas or 110 volt
Do you have any lights working on the front panel? If not most lower circuit boards have a small fuse on the circuit board. shut down ALL power before checking for the fuse.The lower board has both 115 volts as well as 12 volts. If the lights are working on the front panel then most likely the lower circuit board is faulty and will need to be replaced.
Mar 08, 2014 | Dometic RM2652 Refrigerator
It runs the battery down
Does your frig have 110, Gas and 12 volt setting? ... or is it auto select?
This is the way they should work ... if there is 110 Volts, it should run on 110 volts. The device is still controlled by 12 volts but the heat source is electric. If there is no 110 volts, it should switch to gas as a heat source. Same deal with the control, runs on 12 volts. If there is no electric and no gas, it should select 12 volts for a heat source ... same deal with the control. Problem with 12 volt source for heat is it GOBBLES up the power in your battery.
How is your battery? Do a volt test on the battery and the charger. Charger should run about 14 volts. Battery should provide at least 11 volts. If it is such that you can measure the acid, a good reading is 1200. Your charger can provide only about 15 amps charging power. Your battery should be able to provide up to 110 amp/hours.
If you do have electric and gas, it may not be your frig that is killing the battery ...
Thanks for your quesiton @ FixYa.com
Mar 21, 2011 | Dometic RM2852 Refrigerator
Model 211 Dometic, can not keep pilot lit, do I have to have it hooked up to 12 volt
Dometics work on propane, 12 volt or 110 volts, if pilot won't stay lit then you prob have a control board defective. Apply 12 volts and see if pilot stays lit, then you will know.
Oct 16, 2009 | Dometic Refrigerators
Is there a 12volt coil in a Dometic rm52 refrigator
What you would need to do is get an inverter to power the icebox. Turn the 12 volts into 110 to power up the compressor. THE INVERTER STORE has aone for $199
May 16, 2009 | Dometic RM2652 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
362 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
