Question about HP Color LaserJet 2600n Printer
Printer is not working
I have a HP Color Laserjet 2600n printer that will not print after I restored the main service factory settings (in error). The document hangs in the print que and says unable to connect. Status is Ready and on-line. I've tried everything. Any suggestions?
  • 1 more comment
  • pwannamak731 Feb 13, 2009
    I have tried that and it doesn't work.
    The printer is set-up as a network printer and I've tried to re-install from the print server. I cannot locate the CD with the installation so I can't re-load it onto the server. I'm not really a computer technie so hopefully I'm conveying my responses okay.
    It worked! Thanks.
  • HP Master
  • 685 Answers
Try to unplug the printer from the wall and plug it back in.let me know how this works
Posted on Feb 13, 2009
  • 1 more comment
  • Juanita Vega
    Juanita Vega Feb 13, 2009
    have you tried to reinstall printer from scratch?
  • Juanita Vega
    http://h20000.www2.hp.com/bizsupport/Tec... here is where you can redownload the printer from
  • Juanita Vega
    can you please rate me on how i did to help you
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
I have a macbook and an hp2600n printer and i have never gotten a good color print on it. do you know if I need to install something so the colors that you see in the computer are similar to what the...
Improving print quality Use the print-quality settings in the HP Toolbox to improve print-quality problems. The following menus contain paper type, print mode, and print-quality settings. To restore the default settings, open the HP Toolbox and click Device Settings. Then click Settings, Service, and in Restore Factory Settings, click Restore. Paper Types menu The purpose of this menu is to specify the print mode for paper types which are non-specific. To make changes in the Paper Types menu, make the desired selections and click Apply. Print quality menu Under the Print Quality menu in HP Toolbox, there will be an Optimize section containing a number of On/Off adjustments which will apply to all media types.
Oct 26, 2010 | HP Color LaserJet 2600n Printer
I am trying to change color laserjet 2600n back to English and need some assistance. can you help?
Restoring the factory-set defaults
Restoring the factory-set defaults returns all of the settings to the factory defaults.
To restore the factory-set defaults
1 (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press
Use the
(SELECT).
2 (LEFT ARROW) or the (RIGHT ARROW) button to select Restore defaults, and then
Use the
press (SELECT).
The device automatically restarts.
Then you need to change the default settings back to what they were.
Oct 19, 2010 | HP Color LaserJet 2600n Printer
No color on the laserJet 2600n
On the control panel (PRINTER) , Print settinGS, there must be a option to activate/desactivate print without color, only using black cartridge, you should desactivate this option and the printer will print on color.
If you couldn´t locate this option, restore the original settings on the control panel (printer) the error must be resoloved!
sorry for my english!
Oct 21, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
HP 2600 COLOR PROBLEM
I am not sure what out of position refers to but if it is a setting in the printer this should fix it.
Restoring the factory-set defaults returns all of the settings to the factory defaults. Restore the factory-set defaults
  1. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Service, and then press c00317851.gif (SELECT).
  2. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Restore defaults, and then press c00317851.gif (SELECT). The device automatically restarts.
  3. Hope this helps
Mar 24, 2009 | HP Color LaserJet 2600n Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
My printer 2600n is printer continious pages....
You can restore the printer as factory setting by pressing Left & Right button & restart the printer. Then again configure the printer may be it will work.
Thanks
Sep 08, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
125 people viewed this question
Seeker5211
Seeker5211
