Question about Dell Latitude C600 Notebook
Dell c600 problems with: charging/keyboard/pointing device
my c600 is second-hand and has a few problems, the main one being that the keyboard is very annoying as i can't just type, i have to press keys 5 times sometimes to make it appear.
the mouse is generally ok but i want it to work smoother as it jumps a few cm's.
and finally when it's plugged into the mains it doesn't charge.
please help
regards
sara freitas
  • 31 Answers
You can try online antivirus scan firstly, like NOD.com, AVG.com. If everything is OK, try to reinstall OS,or RMA
Posted on Feb 13, 2009
Hi. I have a dell c600 and the keyboard and touchpad are not responding when I boot to windows. When I go to BIOS set-up the keyboards work fine.
Plug in a usb keyboard and mouse. Reinstall your keyboard and mouse drivers through the device manager. Let me know if you need help with it.
Mar 18, 2010 | Dell 0Y3740 Keyboard
Dell C600 No boot, all lights on exept battery charge indicator
u may need to source a main board..and change it..hope it's still under warranty ...
May 22, 2009 | Dell Latitude C600 Notebook
Dell latitude c600, battery not charging even charging sign is shown in windows (battery is ok and checked by another dell laptop) whats problem?
hi im josh in cebu phils.may i help you. friend try to check the small wire white near the batt.or check the connections if it is not shorted or disconnected. or try to replace new batt. good luck
Feb 22, 2009 | Dell C600 (002UH) Motherboard
MY DELL LATTITUDE C600 TURNS OFF AUTIMATICALLY
hi there, you can try this unplug the powercord from the pc and remove the battery and than press the power key than replace the battery adn plug in the power cord and let it charge for a hour or so and than try it again. if it boots good if not try to press the del key right after you turn on the unit and check the settings of bios to see what they are set at and try to set it to default or failsafe than save on exit and reboot and see what that does
Dec 18, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
C600 not starting
Check memory and CPU first, typically they cause shut offs. Try battery, AC to laptop and AC via port replicator. Borrow one if need be, but it's good to check these options
Aug 26, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Help
Hi
I am afraid Dell did no plan Windows XP for Latitude C600 thus Dell has not made released certified drivers.
Generally, Windows XP SP2 should have most of the drivers built in. Reply if you have device(s) which lack drivers and I will get you the drivers at best effort.
Also, try Windows 2000 drivers. Normally it should work
Latitude C600 Windows 2000 driver list -
http://support.dell.com/support/downloads/driverslist.aspx?os=WNT5&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=LAT_PNT_P3C_C600&hidos=WW1&hidlang=en
Mike
Apr 19, 2008 | Dell Latitude C600 Notebook
INSTRUCTIONS
Hi
Check Keyboard Assembly on Dell Latitude C600 - http://support.dell.com/support/edocs/systems/latc600/sm_html/remove.htm#999019
Mike
Mar 08, 2008 | Dell 0Y3740 Keyboard
My c600 is not puttin power in battery
if its the battery with a press button that lights up 5 green lights.. if u hold it for about 6 seconds it should light up all or some in a row like 000.. ( depends on charge it has) after 6 seconds none should flash , they should turn off . if any do flash or led green are missing in between its likely a bad battery.
Sep 29, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
C600 DEATH
Hi Jack, When you say green light are you referring to the battery led? If yes it might be your A/C adaptor causing the problem. I've had laptops flash the battery like it was going to charge then stop. If the A/C isn't supplying power and the battery is dead you could see your symptoms. If its not the A/C adaptor more information would help a diagnosis. What were the circumstances that lead to this, exactly what lead died and so on. Let us know if we can help further and don't forget to rate the posting.
Jan 04, 2007 | Dell C600 (002UH) Motherboard
Dell Latitude C600 Notebook Logo
76 people viewed this question
Alun Cox
