Question about Aerogrow Aero Grow Aerogarden White
New oregano pod has mold fuzz
Started new herbs 1 wk ago.  Oregano shows no growth, but mold fuzz noted on the soil.  Will it grow?
  • 34 Answers
Sounds like you have to much moister and not enough air flow, i would start over and place in a better air flow area..
Posted on Feb 17, 2009
Can you deliver witlof to Perth?
SORRY this is not a food ordering website .we do not have anything here for sale nor do we deliver any produce any place
May 30, 2016 | Cars & Trucks
What can I substitute for marjoram in a soup recipe?
http://cooking.stackexchange.com/questions/11543/substitute-for-marjoram
Apr 11, 2015 | Kitchen Appliances - Others
How do I set the oven on100.
I'm guessing that you want your oven at 100 degrees for drying some food/herbs, or culturing homemade yoghurt. I do all of those, so know the temp range required; 95-110. Most ovens can't be set as low as 100, but the cool thing about a gas range is that the pilot light keeps the interior temperature close to that, and if you keep the oven interior light on, that helps. Get an oven thermometer, costs under $10, test oven temp. If your oven doesn't do it you can get a pizza stone or even a few bricks, preheat the oven to warm the stone/bricks on the bottom rack, turn oven off. Then put in your product of choice on top rack. Leave yoghurt in for 8 hours, leafy herbs (sage, thyme, oregano, etc) for 12 or more hours. If doing yoghurt, don't open door, consistent temp is important. If doing herbs, crack the oven door open slightly with a wooden spoon to allow moisture to escape, critical to drying. I hope this helps.
Dec 09, 2012 | Kitchen Ranges
How to make oregano oil?
Oregano oil is an essential oil and has to be extracted from the dried, flowering tops of the herb by steam distillation.
Here you find precise description:
http://home-distiller.com/essential-oil-distillation/
and here some info about oil:
http://beauty.indobase.com/essential-oils/oregano-essential-oil.html
If you don`t need it pure, you can use method of maceration:
For this process plants are placed into a bowl of warm vegetable oil which makes the plants oil cells rupture and absorbs the essential oils. The bowl is then agitated for several days. The resulting oil is filtered and ready for use as a massage medium.
If you need it for cookery:
3 oregano sprigs, lightly crushed
2/3 cup extra-virgin olive oil
In a glass measuring cup, combine the oregano and olive oil. Cover and refrigerate for at least 1 and up to 2 days. Discard the sprigs before using. Source(s): http://www.foodandwine.com/recipes/oregano-oil
May 08, 2011 | Basil Cycling
Do & Discover Crystal Growing kit came with 2 spanish ONLY directions...How do we get the right dirsctions so my son can Do & Discover?!
I patiently used Google Translate and got this. The instructions may not be in perfect English, but it's good enough to understand. Good luck :)
GROWING CRYSTALS
1.
experiments require a large measurement cup (at least 32fl oz / 0.9 1) Heat resistant glass mix the powder and boiling water. The vessel measures must be glass or plastic Resistant to heat. You also need a medium saucepan (at least 32 fl oz / 0, 9 1) to boil water. Separate carefully cut molds, as pictured. Make sure to leave a border around each mold. Also remove sharp edges from the edges with scissors.
2.
Use a large glass measure (at least 32 fl oz / 0, 9 1) (not included) to measure 0.68 liters of water and pour into a medium-size saucepan. Heat the pan until the water boils.
3.
Open the bag of potassium sulfate 10 (diamond frosting) with chemical crystal growth and pour the contents into the glass of measures.
4.
Pour boiling water in medium saucepan shot glass with the contents of the bag 10.
5.
Stir the mixture with the big stick until all the grains are completely dissolved chemicals. NOTE: Let the mixture cool for 5 minutes after the grains have dissolved.
6.
placed 2 rocks on the bottom base of the 5-sized plastic molds "C" of growth. These basement rocks should rise only about 3 / 4 "(2cm) from the bottom of mold growth.
7.
Pour the chemical solution / water shot glass molds in size 5 "C" for crystal growth. Make sure to fill each mold in the same way, leave an inch (8mm) of space between the liquid and the edge.
8.
After removing the bottle cap coloring dye, carefully cut with scissors (not included) the tip of the boat. Individual drops slowly drops of dye into the mold of crystal growth. see diagram following Mercedes to mix colors. Once you add the dye mixture solution with the small mixing stick. NOTE: Do not add dye to the mold of a glass. transparent crystals are better for the electronic.
9.
Place the mold of crystal growth in a place where not disturbed by movements or changes in temperature. crystals begin to grow in a matter of hours. let the crystals grow for three or four days without disturbing them. You can then remove the crystals from the solution. For best results, wash the crystals abundantly in the sink to remove excess dye and place on a newspaper or paper towel for a day to dry.
10.
if the mass of rock crystal and the base have been a square shape due to the structure of the mold growth, you can break the remaining crystals that form the block so that the crystalline mass display look more natural from the geological point of view. to expose the glass, LED lights the base by pressing the button on the bottom. transparent glass placed at the base and see how it changes color. if you are not using the base, be sure to extinguish by pressing the button again. to replace the battery, remove the cover with a screwdriver as shown below. NOTE: with the help of a magnifying glass, look closely at the detailed crystal structure of the crystals finalized.
Beak-shaped crystals: follow steps 2-10 with the following changes: In step 2, only 0.34 a boil water. In step 3, use the contents of the bag 11.
In step 6 uses the five molds size "D" of growth of crystals with a single rock in each base.
In step 8 uses color guidelines mold "D" (crystals spike) in the diagram below.
NOTES: replacement of the battery base. Place the base upside down. Now you can remove the battery cover to access it, as shown in the image below.
Jan 10, 2011 | Edu-Science Toys
Why did't my garden do well?
You can do either, if you purchase a new seed kit you know the varities have been tested and grow in an AeroGarden. If you plant yourself, but sure to look for small or dwarf varities and lean toward water loving plants.
What problems did you have with your other herbs, not basil?
Sep 29, 2009 | Aerogrow AeroGarden
I started my aerogarden 1 week ago today and 3 of the pods have not sprouted. i checked the seeds and they have not even started germinating. im getting nervous. This is the gourmet herb kit that comes...
well i recently also bought a aerogarden classic which i presume you to have it states in the aerogarden hand book in the master gardener kit ( which is a seperate seed kit purchase grow your own seed kit in other words! ) it states " even though great care and consideration is taken into producing the grow pods and selecting of seeds long transportation in humid or wet conditions may destry the seed" but this does not sound like you situation it clearly statets standard germination rate for a aergo garden is 4 days to rwo weeks tops you should also take into consideration if the size of seed some seeds have a greater tolerenace of water and need a bit more time for the water to germinate the seed regarding any more answers feel free to ask me on k_kv7@hotmail.co.uk
or easy enough read through this simple PDF its not relevant to the gourmet herb kit but the genral processes apply to all seed kits and gives you some good advice on all aspects from pruning to haarvesting and most challenging of all whe you have fruitnig crop how to polinate.
http://www.aerogarden.org.uk/files/Master%20Gardener%20Seed%20kit%20Guide.pdf
hope i was of help
Khawsar Alom
May 01, 2009 | NRS AeroGarden 7-Pod Pro-100
Dill & basil not growing
Hi kadoolittle, some pods do not sprout but can be return for a replacement.
Check out the Dill article on the Aerogardeners Wiki for more info on growing it in the Aerogarden.
http://aerogardeners.wikia.com/wiki/Dill
Jan 21, 2009 | Aerogrow AeroGarden
Aerogrow Aero Grow Aerogarden White Logo
394 people viewed this question
Top Aerogrow Garden Experts
Iron
Iron
Ed Hauk
Ed Hauk
Level 1 Expert
Tom Chichester
Are you an Aerogrow Garden Expert? Answer questions, earn points and help others
