Question about IBM ThinkPad 600E 2645 Notebook
Ibm think pad 600e
Starts to boot, screen comes on ibm upper right, think pad lower left and 261568 kb ok upper left, then jams and does not continue. tried f 8 button during boot, one time got to safe boot, jammed in middle. That approach has not worked since.
  • 3 Answers
Do a search for memtest86.iso. Burn this image to a cd and reboot your computer. When your computer reboots it should begin checking your memory for errors. If you still have problems it might be your hard drive.
Posted on Feb 13, 2009
IBM Think Pad 600e Bios locked. Need Unlock Password Please help.
To reset the BIOS password on your IBM laptop read the information from this link.
Apr 01, 2011 | IBM ThinkPad 600E 2645 Notebook
Hand-me-down IBM Thinkpad 600E 2645 has blinking LCD video XP O/S
This sounds to me like either your flourescent lighting tube is beginning to go bad ,,, or the inverter is going bad ... or even both. :-)
The cheapest and easiest solution for you is to simply replace the LCD screen (replacing the inverter or the tube are actually a bit cheaper, but not quite as easy to do - most computer repair centers will try to talk you into a new screen anyway). This is actually very simple for either you or someone you know who is an avid "do-it-yourselfer". IBM makes ity very easy. You will find easy, detailed instructions in the ThinkPad 600/600E (2645) Hardware Maintenance Manual, IBM S10L-9619-03 June 1999 available for FREE downloading in .pdf format on IBMs website. Follow this link to some really sweet deals on LCD screens for your 600e on eBay for under $35.00. http://shop.ebay.com/items/?_nkw=ibm+thinkpad+600e+lcd+screen&_sacat=0&_trksid=p3286.m270.l1313&_sop=12&_dmpt=Vintage_Electronics_R2&_odkw=IBM+tube&_osacat=0
Remember you can always connect an external monitor to your ThinkPad until your new screen arrives if you have one. The manual should also give you instructions to change out the tube if you wish to save a few more bucks and try that route. Hope this will FIX-YA! Please leave your feedback and let me know!
Jul 27, 2009 | IBM Computers & Internet
Can't get the IBM Think Pad 600E to start.
You need to get into the BIOS setup.
Turn off power to the computer. Wait about 30 seconds. Hold down the F1 key while you turn
on power and keep holding down that key until the setup screen comes up. Go to the network boot section and disable Network Boot. Save setting and restart. That should fix it.
Mar 15, 2009 | IBM Computers & Internet
On a ibm 600e, how do I boot from a cd? I'm
ok go to the bios system by pressing esc or F12 or F2 key when the computer restart. After that change the boot sequence. CD drive first after that HDD or follow the instruction that are given by computer in bellow or side, after configure just press F10 for saving.
Mar 14, 2009 | IBM ThinkPad 600E 2645 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
IBM 600E
Hi Aaron,
Sounds more like a hard drive issue, although it could be either or both.
Tap either F8, F, F10, F12 or Del when you boot up. You have to do it right on the bootup. This will let you enter the BIOS/Advanced Settings.
See if you can Start Windows in Safe Mode from there. When you get to the Desktop, in Safe Mode, you might be able to do a System Restore back to a time before you started experiencing problems, although you will lose any configuration settings you made after that point.
Also if you could do a Repair Windows with a system disk, that would be wise.
The reason I mentioned so many possibilities for buttons to enter the BIOS is because is varies from machine to machine. It usually says which button it is at the bottom of the screen for a very short time when booting up.
Try that and let me know how you get on..
Chris (ziraffa)
ps The fact that you can see your RAM size is a good sign, with regards to the actual hardware. I think the worst case scenario is probably having to reinstall your operating system from scratch.. and then the hassle of finding and installing the hardware drivers so that the new operating system can 'recognise' the motherboard, and the network cards, sound etc
Jan 17, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpad 600E 2645 not boots
Format the harddrive and install an Operating System of your choice.
Good Luck.
PS: You can probably disable that memory check in your BIOS to speed up your boot time as it is not necessary.
Feb 19, 2008 | IBM ThinkPad 600 E Notebook
Thinkpad 600E
IBM Thinkpad error code 19990301 is a Hard-Disk sector problem. Basically your hard-drive is faulty and you need to replace it. This is why it wont boot; because the area of the hard-drive that stores data is damaged.
Sep 20, 2007 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
119 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
