Question about Palm Tungsten E Handheld
Documents to Go: Fatal Alert
Normal 0 I downloaded a document to my Tungsten 3 from my PC using Word 2000. The transfer was successful. The problem is when I select the document on my Tungsten 3 it starts to load OK but then I get an error code window that states: (EMUL68KMAIN.C Line:403 illegal instruction 8888 at address 082D1E4 ) First time I’ve tried to load a Document.Thank you for your help in advance.
Frank Gonzales
  • Frank Gonzales Feb 25, 2009
    Thank you very much for the suggestion. I have already tried both and it still dose the same.
    thank again.
    Frank
    Guru:
  • 1,049 Answers
It could just be that document, but I suspect if you've followed typical trouble-shooting steps you wouldn't be posting unless you already tried other documents. If that is the case, I would recommend you uninstall and reinstall documents to go from your device.
Posted on Feb 24, 2009
Everytime I use the search fuction I get a fatal alert message
Make sure you have over 25% remaining space on your HandHeld and try again. Otherwise try a hard reset: Hold down the power button and click the reset button.
For more help:
admin@dec-help.co.cc
DEC Electronics Limited
www.dec-help.co.cc
Feb 26, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Won't load documents to go therefore I can't transfer documents
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Jan 11, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten e2
Take a look at your address and birthday sections and see if you can find duplicates bith in your PDA and you desktop.
Jan 05, 2009 | Palm Tungsten E2 Handheld
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
Fatal alert
I've had the same problem. Mostly I've found that it is a corruption with the documents to go database. (I'm using version 7). To make the error go away, you can delete the docs to go application and the documents and then reload both (make sure you set the desktop to override the handheld until you've got the docs back on your PDA.) I'm considering upgrading to docs to go v10 to see if this will fix the problem ...
Jul 23, 2008 | Palm Tungsten T5 - Multilingual Handheld
Fatal alert
Do you have an MP3 installed on your Palm?
You might have to reinstall it.
Jun 13, 2008 | Palm Tungsten T5 - Multilingual Handheld
Fatal Alert
Though Docs to Go is supported by Palmone, it is still a 3rd party software and will jam your unit like you wouldn't believe. I reloaded mine 15 times before I gave up and quit using it. The Fatal error is an all out jam. The Docs can even duplicate themselves and yes you end up dumping the program from your e2 and reloading before it will work again. The e2 is good and I made mine do internet wirelessly but could never whip Docs.
Mar 03, 2008 | Palm Tungsten E2 Handheld
Fatal Alert problem
We prayed and asked God to save the data even though we had to do a hard reset. Data was preserved entirely! For this we give thanks--and praise.
Rob Starner
Feb 19, 2008 | Palm Tungsten E2 Handheld
Fatal alert [Memory Mgr,C,Line:3751, Free handle
Thoroughly flush (delete) documents to go using the tool below and then reinstall.
Worked for me two times over the past two years when my E2 has gotten sick.
http://support.dataviz.com/support.srch?docid=13445&pid=2000
Dec 01, 2007 | Palm Tungsten E2 Handheld
Documents to Go
You need to re-install Docs to Go. The option would be visible on your PCs Docs to Go Menu. Rest assured, no cold resetting, no hassles. Sajid Ali Khan Karachi, Pakistan
May 31, 2006 | Palm Tungsten E Handheld
Palm Tungsten E Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
