Question about HP LaserJet 4250n Printer
Can't print from top
I can't get it to print from the manuel feed
  • darlene_john Feb 16, 2009
    yes the problem was fixed, some how the setting got messed up, it wasn't as bad as I thought it was gonna be
  • Terry Watson
    Terry Watson May 11, 2010
    When you open the manuel feed door and put paper in it should detect and pull from there. If it is not, is it giving any error code or what?
    Problem Solver:
  • 7 Answers
Replace the manual feed roller and separation pad.
Posted on Feb 14, 2009
  • plittle81359
    plittle81359 Feb 16, 2009
    you need to go into the settings on the control panel, and use the item + key to go through the menus to paper handling. In here find manual feed, and change it appropriately - both what will be loaded in tray 1 = manual feed, both type and size. For example:
    Determine how the printer will use
    Tray 1.
    FIRST: If paper is loaded in Tray 1,
    the printer will pull paper from that
    tray first.
    CASSETTE: A paper size must be
    assigned to Tray 1 using the
    TRAY 1 SIZE option (the next item
    in this menu when TRAY 1
    MODE=CASSETTE). This allows Tray 1
    to be used as a reserved tray.
    This item appears only when TRAY 1
    MODE= CASSETTE. Set the value to
    correspond with the paper type
    currently loaded in Tray 1.
  • plittle81359
    plittle81359 Feb 17, 2009
    did you try changing the setting, and what was the result? Did you also change the setting on your computer?
Will not feed in paper
TONY, UNPLUG PRINTER FOR 3 MINUTES REPLUG TRY PRINTING SOMETHING ALSO YOU MUST CLEAR ALL PRINTING JOBS THAT ARE IN THE MACHINE NOW,, CALL CUSTOMER SUPPORT FROM NUMBER IN YOUR MANUEL ,,TRY ALL ABOVE THANKS
Jan 24, 2016 | Office Equipment & Supplies
Does not print on the receipt. The paper feeds out as if it were printing, but it comes out blank.
try replacing the ribbon for the printer that prints the reciepts. they do need to be changed after some period of time. Check your owners manuel for instructions.
Mar 20, 2015 | Casio PCR-T2000 Cash Register
Brother mfc-7420, how do I get off manuel paper feed
Thank you for following me up, I managed to discover that the document I was trying to print was set up for manuel paper feed, other documents subsequently went back to normal after printing the offending document. However is there a setting on the actual printer to control this.
Regards John
Oct 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
I work at a prison and am in charge of setting up the new booking system. I have a platform for our id cards set up. when i feed a card into the manuel feed tray it cuts off the top what can i do to...
Did you check the software to see if there is a resizing of the card? there should be a parameter of different sizes that one can use, look at that and also if you click on your printer settings and in "print preview" there has to be a table with different sizing on it. Just go to the top left corner of internet explorer, File, scroll down to print preview, thanks for using FixYa
Jan 31, 2009 | Office Equipment & Supplies
Every time i try to print multiply pages a window opens up
select the proper tray from the propeties of printer. it will take paper from that tray.
Nov 26, 2008 | HP LaserJet 1020 Printer
My Lexmark X1185 will scan but will not feed to print
You probably need to adjust the roller or do an alignment. Your owners manuel should have the info on how to do this.you can probably clean the roller . If it shiny it will not pull up the paper. Check it out.
Oct 29, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
mongrelken.
May 20, 2008 | Brother HL-2040 Laser Printer
Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
May 18, 2007 | IBM Infoprint 1140 Laser Printer
HP LaserJet 4250n Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
