Question about Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 177
I am getting this error as soon as I try to send a print job to the printer. Anyone have any ideas what this could be?
  • tallygeek Feb 24, 2009
    It ended up being the fuser.
    Guru:
  • 1,049 Answers
I think that's a buffer overflow error, but if you get that error no matter what you print I would check to make sure your memory isn't bad.
Posted on Feb 24, 2009
  • NA NA
    NA NA Feb 25, 2009
    Good to know, Thanks.
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
Fatal error 20
this is a memory issue. remove the memories an dopen the printer if it open ok, close it and try putting one memoery at the time.
Dec 07, 2013 | Xante CL30 HSE Laser Printer
Fatal error 142 xante Cl30
it's a problem with cyan ID. clean the cyan drurum's contact and the cointacts inside the printer where cyan drum ''sits''. if not try with a used drum.
Aug 22, 2012 | Xante CL30 HSE Laser Printer
Fatal error 153
check with a different black drum
Jan 17, 2012 | Xante CL30 HSE Laser Printer
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
177 Fatal Error
Error 177: Thermistor indicates Low Temperature (COLD) Error.
Usualy the fuser has overheated first (error 172/176) and tripped the thermal protection causing the fuser not to heat up anymore.
Normal procedure if a restart doesn't fix it is to replace the fuser unit.
Dec 29, 2010 | Xante CL30 HSE Laser Printer
What does error code 032 fatal error mean and how can I fix it
Here's the link to your 500 page Manual. I used the search function at the top of the Abobe Doc which it is formatted as and typed in your error.
It won't call up anything about 032 but Fatal Error recommends only "Call For Service".
Not very helpful is it?
Oh well, please don't thrash my rating with 2 blue thumbs or less. I tried. :(
Regards,
MArcus
Sep 16, 2010 | Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 127 Code
When to many consumable is low at the same time.
Oct 08, 2008 | Xante CL30 HSE Laser Printer
Xante Cl30 laser printer error
Error 125 is indicating an error detected at MT home position, which means the transfer belt may not be returning to the proper start position. The normal solution to this, if it persists after a restart, is to replace the transfer belt.
Mar 26, 2008 | Xante CL30 HSE Laser Printer
Poor registration on Xante CL30 HSE
Make sure the drums are properly seated in their cradels, and if posible, avoid designing with white small text in heavy solid areas that are made up of process colours. For reverse type in a black background, use spot color black rather than rich black. Other than than printing on a not as heavy card, that is about all you can do.
Aug 19, 2007 | Xante CL30 HSE Laser Printer
Xante CL30 HSE Laser Printer Logo
240 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Igor Studennikoff
Igor Studennikoff
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
