Can any one tell me what happens after the lamp screws are removed?
Please tell me that no screws disappear across the room followed by springs... eek..! on a technics 1210 popup light .
Any help muchly appreciated
Correct, there are no flying spring screws. However, the screw on the pop-up light cover is very tiny, so you have to be careful not to strip or lose. Make sure you use the proper tools.
On my Technics 1210 mk2 turntables everytime i press the stop button, they dont stop dead but start...
(More)
On my Technics 1210 mk2 turntables everytime i press the stop button, they dont stop dead but start going in reverse. I have just replaced the pitches on them aswell. Any idea?
CD changer occasionally works then randomly skips and won't play nor does it show all cd's that are...
(More)
CD changer occasionally works then randomly skips and won't play nor does it show all cd's that are loaded.
my deck has sound through the mixer into headphones but there is no output out of mixer.I have...
(More)
my deck has sound through the mixer into headphones but there is no output out of mixer.I have swapped decks over to check it isnt mixer and it does the same in the other channel while the good deck works fine in both channels, i have swapped cables as well,but no difference.Any ideas please
I was spinning records the other day and with no warning my 1210mk2 just turned off and would not...
(More)
I was spinning records the other day and with no warning my 1210mk2 just turned off and would not come back on. any ideas on what caused this and what steps to fix it I might try?
