Question about D-Link Web Smart DES-1228P 24-Port Ethernet Switch (DL-1228P)
D-link lights are all on
All the d-link lights are on and I can't get them to go off..
i tried resetting at short and long intervals to no avail. please help
D-link Web Smart Switch
DES-1228P
24-port
  • 2 more comments
  • Chalet Heidi Feb 23, 2009
    All LEDs on my DLINK 1228P are lit on power up with no connections to the switch. The reset button does nothing. The switch has worked perfectly and continously for 9 months and today it does nothing!!
  • anduze alexander Mar 04, 2009
    TSKHAM, that is very helpful, now i need some contact numbers that are working and verified, the ones that came with the unit ring busy 24\7......
    877-354-6555(not good)
    supposed to be for business sales or something like that who they refer you to for the switches issues....
    I need a good number to the business sales division, anybody ?????
    I need a good number to the business sales division, anybody ?????````````````````````
  • rzbojna Apr 21, 2009
    I have the same issues. All lights are on and reseting the unit is not helping anything.
    Had the same issue in January. D-Link was very good with replacing the unit the same day. 3 months later second unit is doing the exactly the same thing
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Sorry to be bringing you the bad news but the D-Link has internal electronic faults. Most common would be the +5VDC voltage regulator shorting and supplying the full voltage to the logic ICs. They in turn burn because of over voltage. If the LEDs would at least blink on start-up, then problem would be on the reset/init trigger. On the other hand, if on power on all the LEDs lit up continuously, then the initial condition would be the most likely scenario.
If you would factor in the cost of repair, the down time on the entire network and the efforts to effect a reasonable repair, you may want to re-evaluate your options and consider replacing the switch being mission critical in a wired network.
A request...I am aware that I have not provided you a fixing solution but just stated a technical opinion. I would appreciate that you rather not rate this at all since any rating other than a 'FixYa' would lower down my ratings. I could just not let your request for assistance go unanswered.
Good luck and thank you for using FixYa.
Posted on Feb 13, 2009
    Problem Solver:
  • 7 Answers
I don't think it has anything to do with the voltage its an issue with the ship on a certain batch , again not all the DES-1228P have that issue only few.
I am sure if you contact D-link they will replace the switch as it is a 5 years warranty
Posted on Mar 03, 2009
  • tskham Mar 04, 2009
    Hi Ezudna,
    Try 08718730909 for second line support have you serial number ready and a Proof of purchase.
Airbag light reset code
You would need to reset the warning light and then see if it comes back on, which would indicate a fault still there. Try this procedure
http://s16.photobucket.com/user/rogersb/media/AirBagReset.jpg.html
"How do you reset the airbag warning light in a '94 Camry?
A: Clearing the warning light in '92-'96 Camrys by the following procedure:
In the DLC1 or DCL2 (data link connector under the hood, see following diagram)
Use two short wires, one wire at terminal TC and a different wire at terminal AB
With the ignition key ON - wait 6 seconds, then:
Ground terminal TC to good body ground for one second
Then ground terminal AB for one second
Then TC one second
Then AB one second
Then ground TC until the light blinks.
Make sure the interval between grounding terminals is not more than 0.2 sec.
Remove the ground wires
Be very careful to only use the correct terminals."
Jan 21, 2014 | Toyota Cars & Trucks
Airbag light on
Try this procedure, but if it comes back on, your airbag is faulty, of course.
A: Clear the warning light in '92-'96 Camrys by the following procedure:
Then TC one second
Then AB one second
Jun 23, 2013 | 1993 Toyota Camry V6
Need to reset the button for the mileage the perform service keeps coming on
The shop service manual is rather vague on this subject.
It says that you must select "Service Interval" and once in the service interval display, the interval can be changed by pressing the "Step" button.
The "Reset (Yes/No)" display only becomes available when the service interval is changed.
It doesn't explain where these buttons or the display is located.
This proceedure is probably better explained in the Owner's Manual.
Nov 28, 2010 | 2005 Jeep Liberty
NEEDS MAINTENANCE light on at 46,666 miles
The light comes on at fairly short intervals ... even to let you know that you need an oil change. The mileage at which it comes on will depend on when it was reset last time. Here's a link to Yahoo Answers to turn the light off yourself.
http://answers.yahoo.com/question/index?qid=20080305080020AA1XbGo
Jul 23, 2010 | 2005 Honda Civic
How do you reset change oil light on mitsubishi outlander
Turn the key off.
Press the "Info" button on the left of the dash cluster until your maintenance miles/months screen is displayed.
Press and hold the "info" button until the maintenance screen begins flashing.
Release the "info" button and then push and hold it it for one second.
Your Maintenance intervals should reset to +6 months and +7500 miles since the last interval amount.
Note that if you have not reset it for more than one interval, you may need to do it more than once. If you have not done it for many intervals, you may need to have it reset with the scantool at a dealer, as I have run into a handful of vehicles that the oil change reminder locked up after 3-4 "intervals" were skipped/not reset.
Sep 11, 2009 | 2007 Mitsubishi Outlander XLS
Intermittantly for short intervals while running
Make sure you replace the fuel and air filter.
Sep 03, 2009 | 1997 Buick LeSabre
Citreon Service interval passed now Engine Man. Light is on
reset it it will be fine.that is a pre set code put in by the maker.they do that so when you bring it in thay can say now heres some one that has no idel of whts going on lets make some money.some time they will just reset it but if you look like you dont know then there going to try to make money off of you.not just you im saying some pepoul.the dealler ship evil
Jul 27, 2009 | 2000 Renault 181
How reset service interval light (already changed oil, oil filter, etc)
the service interval "light " has nothing to do with emissions or a problem with the car . There is a rectangle slot on the dash cluster you just use your key and press it and it just resets the counter
Apr 14, 2009 | 1993 Honda Accord
Will Not Run
I had the exact same problem. The tech came by and suggested to run the diagnostic cycle to clear up the error. Nice guy didn't charge for the time. He said Whrilpool has a poor software design.
Problem - LED blinks 7 times when the temperature doesn't come up to the degree F required for the wash. This may happen if someone took a shower minutes before starting the dishwasher.
The Tech said, Whirlpool should have allowed a straight forward reset by the customer (instead of disabling the machine for a tech to come by and fix the minor issue).
Here is the solution.
Solution - (is pretty much the same to clear up the other software glitches as well)
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Jan 05, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
How to stop the beeper and reset the "code' light on panel?
You have a shorted 2 pad on the keypad.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Aug 21, 2008 | Microwave Ovens
Open Questions:
USA-Nortan@1+877+778+89+69@Norton Antivirus Customer Service Phone Number? For any more detail contact us:-1-877-778-89-69. Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number,Nortan Antivirus Tech Support Number,Nortan Internet Security Customer Number,Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number.
Apr 28, 2017 | Norton Computers & Internet
See all D-Link Web Smart DES-1228P 24-Port Ethernet Switch Questions
D-Link Web Smart DES-1228P 24-Port Ethernet Switch (DL-1228P) Logo
1,047 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
