Question about Kyocera Office Equipment & Supplies
KM 3050 Printing Faintly
The KM 3050 has suddenly started printing faintly. I have checked the obvious and there is plent of toner left, the exposure is on maximum and I have cleaned out what I can - any ideas?
  • daniel_kilda Feb 18, 2009
    Still no joy - it is slightly better, but no readable. Any other suggestions?
This could have been caused by a number of things. The transfer roller, a spongy looking black roller on the left door could be broken somewhere so the roller does not keep pressure on the paper and aid in transfer of tone from the drum to the paper. Check that or you may need to refresh your developer so you need to enter 1087 1087 on the key pad, this will take you to a maininance mode and then enter 130 and start this will take you to a screen and will say something like setting developer, tap execute and then push the start button and after a few minutes your machine will have refreshed your developer. Then hit clear a few times and enter 001 and start witch would take you back to the copier screen. if this does not work just shut your copier off then on and your machine will have reset. Try the Copies agian. Hopefully that will work.
Posted on Feb 15, 2009
Test pgs print ok, jobs= no black only blue faintly appears.
Hi, check if the black toner is properly inserted and check the printing configuration
Dec 09, 2013 | HP PhotoSmart Office Equipment & Supplies
My printer suddenly started printing faintly after undertaking maintenance
who did the maintanance on your machine.
This may be a toner density setting,
But call them up and tell them to fix it. they caused it
Feb 10, 2011 | HP LaserJet P3005n Printer
Just changed the toner and the printer now prints faintly
There are two reasons for faint/ light printing:
1- Toner Saving Mode may be turned-on from the printer OR from printer settings in windows
2- There could be dust/ Toner Dust accumulated on the mirrors and lenses inside the printer, which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hope this helps!
CreativeTECH
Dec 20, 2010 | HP P2055DN LaserJet Monochrome Printer
Copier function prints faintly
Usually the setting that causes that is when you have the toner save function turned on. It saves toner by making lighter prints.
Oct 12, 2009 | Dell 1600n All-In-One Laser Printer
My printer is printing colour red faintly, the toners are new and genuine. it also takes some times before it starts printing.
Sherry, in all probability it is the "scanner assembly" HP can fix this for $279 in the US using HP Express exchange 1 day ship, this was the result of their active chat. I am having the same problem and am going to dismantle the printer myself to see if I can't clean the scanner mirror myself. If you search the following words on google you will find some info, fading red tones laser jet 2605, one of the first results is a page on the HP site specifically on laserjet printers. I wish I had a quick fix that would help; however, a new cartridge won't help!
Feb 09, 2009 | HP Laserjet 2605 Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
Toner splatter and faint double image
replace the toner cartridge or get the cartridge refilled as its about to empty .
Dec 09, 2008 | HP LaserJet 1020 Printer
My printer won't print multiple pages
The Toner is running low. What is happening is you are low on toner in the MIDDLE of the Cartiridge. Take the cartridge out and jently shake it left to right (be careful you dont make a mess) this will distribute the toner evenly. time to buy a spare as this wont last much longer.
Aug 28, 2007 | HP LaserJet 1100 Printer
Left hand side prints faintly
inside the toner unit, there is a stirring device to broadcast toner over full width of drum. I will guess this is the culprit, the stirring device is not turning. Try this test: remove the toner cartridge and shake it rapidly back and forth. Then try a print, any change?
Jun 07, 2007 | Minolta magicolor 2400W Laser Printer
285 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
