I HAVE A 61" PANASONIC PT61LCX65 PROBLEM STARTED WITH LAMP REPLACEMENT,REPLACED LAMP,DID NOT HAVE ORIGINAL REMOTE TO RESET TIMER ABOUT TWO WEEKS AFTER TV WILL NOT TURN ON AT ALL GREEN LIGHT FLASHES GREEN ABOUT A MINUTE THEN RED THE SHUTS DOWN,GOT ORIGINAL REMOTE NOW THE SAME THING WILL NOT TURN ON TO EVEN RESET TIMER,I IKNOW I NEED EEPROM ALSO,BUT THATS ANOTHER PROBLEM I CAN SOLVE AFTER POWERUP,ANY ANSWERS,THANKS BUCK EMAIL BUCK@CAPITOLMACK.COM
  • 4 more comments
  • BUCK Feb 13, 2009
    NEW REMOTE TURNS TV OFF AND ON,BUT STILL PROBLEM AS SAID BEFORE
  • BUCK Feb 13, 2009
    NEW REMOTE IS ORIGINAL TURNS TV ON AND OFF,BUT STILL SAME PROBLEM
  • BUCK Feb 13, 2009
    LAMP DOOR IS CLOSED,IF POWER LIGHT BLINKS ORANGE,TRIED THAT,REMOVED A REISTALLED LAMP AGIN TO MAKE HAD GOOD CONTACT,CHECKED BULB IN HOUSIING,TO MAKE SURE WIRES WERE CONNECTED.O.K. COULD BE WHAT YOU MENTIONED,SEEMS LIKE BULB DOES NOT POWER UP,ALSO DID RESET AS INSTRUCTIONS,BUT POWER LIGHT DOES TURN SOLID GREEN JUST BLINKS GREEN THEN RED THEN SHUTS OFF
  • BUCK Feb 13, 2009
    INTERNAL OR EXTERNAL?
  • BUCK Feb 13, 2009
    INTERNAL OR EXTERNAL POWER SUPPLY?
  • BUCK Feb 13, 2009
    THANK YOU,BUT REPLACE WHAT?ANY IDEAS?
  • 15,935 Answers
Your power supply is bad.
Lamp is not getting signal or voltage to turn on.
Please replace.
Thanks for using Fix-Ya. A FixYa rating is appreciated!!
Posted on Feb 13, 2009
  • 217 Answers
Please check The lamp cover is ajar. Firmly replace the cover.Check whether or not the vents are clogged
  • Saroj Sharma
    Saroj Sharma Feb 13, 2009
    Kindly download the manual for proper instruction to replace the lamp:
    http://safemanuals.com/user-guide-instru...
  • 19,396 Answers
Check that the lamp door is well closed, and eventually remove and mount back in place the lamp.
Ensure that you did reset procedure correclty.
If this does not fix the problem , then the problem may be a defective ballast board, that is the small board that powers with AC the lamp.
  • 1 more comment
  • Ginko
    Ginko Feb 13, 2009
    To reset timer try the following, applies to different models:
    "With power on, hold down VOL minus button on projection display and
    hold down the PIP or SPLIT button (try both) on the remote
    simultaneously for more than 5 seconds."
    from Reset lamp hours on Panasonic
  • Ginko
    Ginko Feb 13, 2009
    Same method illustrated here: reset Panasonic lamp hourmeter
    I quote: "How To Reset Panasonic LCD Lamp Timer:
    Step 1: I turned the volume all the way up.
    Step 2: Hold the Volume - button on the TV (Not the remote) until it
    was at 0. Keep holding the Volume - button down.
    Step 3: Press and hold the PIP/Play button on the remote until the
    message shows the timer has been reset to 0."
    If that does not work then there is an additional fault, usually the small board that gives AC power to the lamp is faulty.
    Let me know.
  • Ginko
    Ginko Feb 13, 2009
    When you give Fixya to one of us you reward the expert that you vote Fixya, and the rest of us will not provide anymore help.
    Now ask to the expert that you voted Fixya.
    Goodbye.
  • 679 Answers
Did you try transfering remote codes?
  • 1 more comment
  • rockfixya
    rockfixya Feb 13, 2009
    Try to reset your TV --
    1. Plug in the AC Cord, and turn on the power by pressing the
    POWER button.
    2. Press and hold the VOLUME DOWN button on the unit and
    the SPLIT key on the remote together for over 5 seconds
    in power on condition.
    Thanks
  • rockfixya
    Lamp Time Reset Procedure:Be sure to reset the Lamp time to "0" after replacing the new
    Lamp.
    POWER button.
    the SPLIT key on the remote together for over 5 seconds in power on condition.
    When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
    Than try again
  • rockfixya
    Here is the proceedure to replace the lamp and reset the lamp hours.Lamp Replacement Procedure:
    1. Press the POWER button to turn off the power.
    2. Wait for about 1 minute until the cooling fan stops.
    Note:
    The lamp cooling fan will continue to operate for about 1
    minute after the power is turned off. Do not unplug the AC
    Cord from the outlet until the fan has stopped. Avoid
    interrupting the power by using circuit breakers or switchable
    power strips.
    3. After the cooling fan has stopped, unplug the AC Cord from
    the outlet.
    Note:
    Please wait more than one hour before replacing the lamp.
    [ Forced cooling function ]
    If you need to replace the lamp more urgently:
    - The Projection display has a forced cooling feature.
    After the POWER button is turned OFF, and during the
    first minute of the normal cooling fan operation, press
    the VOLUME UP button on the unit and CH UP key on
    the remote at the same time for more than 5 seconds.
    The cooling fan operates for about 10 minutes. (LAMP
    LED will flash 5 times every 5 second and POWER LED
    will flash red for 10 minutes.)
    4. Remove the Front Cover Unit from the latches.
    5. Turn the Knob to the left.
    6. Pull the Lamp Cover out.
    7. Loosen the Screw on the Lamp. Then, pull the Lamp.
    Note:
    Because the Lamp may still be hot, use caution when
    handling.
    8. Install the new Lamp, and tighten the Screw.
    9. Install the Lamp Cover, and turn the Knob to the right.
    10. Install the Front Cover Unit.
    Lamp.
    POWER button.
PT-61DLX75 replace lamp light reset
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
Sep 20, 2009 | Panasonic PT-61DLX75 61" HDTV
Panasonic LCD Lamp Replacement
Here is the manual for your set, the instructions for replacing the lamp are on pages 66-67.
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-61LCX65
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 21, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
We have a PT61LCX65 Panasonic Tv that has purple squiggle lines
TRY THE MENU FOR A COLOR CONVERSION OPTION TO FIX THAT
Dec 16, 2008 | Panasonic PT-52LCX65 44" HDTV
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
PT61LCX65 lamp timer
Hold the volume down button on the tv until the volume is at min. then continue to depress the volume down button on the TV. While depressing the volume down button the tv hold the pip or split button on your remote for approx 5 sec. You will see a box pop up that says lamp timer reset and gives instruction on how to exit.
Jun 02, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
