Question about GE GSS25LGM Side by Side Refrigerator
GSS25LGMF WW Will not dispense ICE or Water, lights are on
The water will not dispense, nor will ice dispense. The ice flap opens but nothing moves in the ice auger or anything. Water will not dispense either but lights on display work. I don't have the same problem as others where the water works but the ice doesn't. Nothing dispenses at all, not cubed, not crushed, and not water. There is ice in the ice holder and the unit is making ice, just will not dispense anything.
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
Posted on Mar 02, 2009
  • 121 Answers
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Posted on Feb 20, 2009
  • Timothy Brooks
    Timothy Brooks Feb 20, 2009
    ..in my case, I bypassed the filter by connecting the two plastic tubes that went to the filter (bypass). ..I did not see the need for a new $30 filter.
Kenmore coldspot refrigerator model 52552100 makes ice but wont dispense it
Below is a fix by another owner of your make and model for the same issue.
Pulled out ice bucket; tried ice dispenser with door latch pressed in and solenoid engaged and motor moved. Tried again and nothing (couple of times). Tried water...all good...good closure of dispensor flap (air pot operated). Opened dispenser (pried off carefully from bottom on this unit not to take off the glued part) and saw the micro-switch broken off of the ice dispenser side. Checked micro-switch (all good). Replaced control bracket...all good to go.
Nov 25, 2016 | Kenmore Refrigerators
Why won't my ice maker work
Hello Cynthia! Most likely the little "flap" inside the door of the dispenser is not closing all the way. My advice is to take all your ice out of the inside of the freezer. Clean and dry out that area as good as you can. Take your hand, and from the bottom, reach up and feel the flap that should close all the way when ice or water is dispensed. Take warm water, pour it from the top, you won't need much, and dry off the little flap as good as can be.
Now, press the ice button, and when you let go, you should hear a clunk or deep sounding slap, that is from the flap closing properly. Same goes for the water. However some manufacturers don't open the flap for water. From this point forward, assuming you heard the flap close, be sure it makes that same noise every single time you use the ice dispenser, or the water dispenser, and your problem should be solved.
May 07, 2014 | Refrigerators
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser is not operating. will dispense ice occasionally. noticed the light in the dispenser opening gets dim. Water is dispensing normally.
When it doesn't dispense , do you hear the auger turning ? If so , then the dispensor flap is not opening completely . This is caused by a rusted plunger in the solenoid which opens the flap . If you use crushed ice often , then could be a build up in the ice shoot which has to be cleaned regularly .
Jul 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
GE GSS25VGMA WW Ice/water dispenser
My solenoid was rusted up due to water condensation in that area.
To get to the solenoid and the ice flap:
Under the control panel there are two holes if you look up under it.
Push a small object into each hole and the control panel will come out.
Release the clips that hold the three wiring harnesses onto the control board, unplug the wiring harnesses and set the control board aside.
Take the 4 corner screws out of the unit that sits behind the control panel and set that unit aside. From there you will be able to see the flaper. The seloniod sits on the left side.
Take the screws out that hold it in and remove it. There is a plunger on the top that should be free to move up and down. It should slide right out but yours might be a little locked up. Pull it out and clean the rust off. Also clean the hole it goes down into. Mine was in bad shape and all rusty but still worked after I cleaned it all up. I ended up spray painting the plunger and the solenoid to prevent future rust and it works like new. (not sure how much a new one is, that might be the better solution).
Now I'm trying to figure out how to stop the water condensation so it doesn't happen again.
Jan 01, 2008 | GE GSS25VGMWW / GSS25VGMCC Side by Side...
GE GSS25LGM Side by Side Refrigerator Logo
847 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
