Question about Microsoft Internet Explorer 7
IE Shortcuts keep appearing
My companay recently applied some group policy that provided shortcut links (favorites) to IE 7, so now they are across the top of my browser. It is annoying because there is only so much real estate and I one of them is useless to me. I've gone int Documents and Settings and deleted them from all users. I've also deleted them by right clicking on them.
Some executable or something is running and keeps putting it back there. Is there anyway to find where it is originating from and delete it?
Thanks
  • vbernard3844 Feb 13, 2009
    I tried it for all of them with the selection of "Add-ons currently loaded", except for those by Adobe or MS One note. Didnt work. There are other selections in the drop-down for add-ons that load without permission and add-ons that have ever been loaded. should i go through them as well?
  • 131 Answers
Try going into tools- manage add-ons and disable browser add-ons one by one. When you get to the right one, your add- in should be gone. You have to shut down internet explorer and restart it every time you disable an add-on for the changes to take effect.
Posted on Feb 13, 2009
  • Gord Thurston Feb 14, 2009
    You could try the add-ons that run without permissions -the ones that have never loaded won't be causing problems. You could try un-installing & re-installing IE7, but it's unlikely that this will work. One thing that will work is a program called "hijack This" by soperman. Do a scan with this & look for a browser helper object (bho) that isn't from a company you recognize. tick the box next to it & press the button that says "fix Selected". This will remove this annoyance when you get the right bho.
How to fix access denaid probems.
Open the Local Group Policy Editor Applies To: Windows 7, Windows 8, Windows Server 2008 R2, Windows Server 2012
You can open the Local Group Policy Editor by using the command line or by using the Microsoft Management Console (MMC).
To open the Local Group Policy Editor from the command line
  • Click Start , type gpedit.msc in the Start Search box, and then press ENTER .
To open the Local Group Policy Editor as an MMC snap-in
  1. Open MMC. (Click Start , click in the Start Search box, type mmc , and then press ENTER .)
  2. On the File menu, click Add/Remove Snap-in .
  3. In the Add or Remove Snap-ins dialog box, click Group Policy Object Editor , and then click Add .
  4. In the Select Group Policy Object dialog box, click Browse .
  5. Click This computer to edit the Local Group Policy object, or click Users to edit Administrator, Non-Administrator, or per-user Local Group Policy objects.
  6. Click Finish .
Jan 28, 2016 | Computers & Internet
Need WordPerfect 13 keyboard shortcut info
[PDF]WordPerfect Office X3 User Guide - Welcome to Corel.com
apps.corel.com/wpox3_online_resources/.../wpox3_user_guide.pdf CorelStarting and closing WordPerfect Office X3 programs . . . . . . . . . 7. Corel Support ... Accessing the latest information . . . . . . . . . . . . . . . . . . . . . . . . . ...... applies Microsoft Word and Microsoft® Excel keyboard shortcuts to. WordPerfect and Quattro ...
Oct 16, 2015 | Computers & Internet
Insert Lexar sdhc card nothing happens
Solution for Windows 7:
Note: Changing of this Group Policy setting applies only to Windows 7 Ultimate and Windows 7 Enterprise editions
1. Click Start and click Run...
2. In the box that appears type: gpedit.msc and click the OK button
3. The Group Policy Window will appear. In the left panel extend Windows Components and click AutoPlay Policies
4. In the right panel locate Turn off Autoplay and double-click on it to open the Properties window
5. Click on Disable. Click Apply and then OK
6. Finished.
hope this helps
Sep 05, 2012 | Computers & Internet
All folders on usb flash memory card changed to be shortcuts , I can't display their contents directly , there is folder called recycler contain an index for the data inside my folders ... i want...
Hello there, sadly you have been attacked by a virus named - RECYCLER. This is a very common virus, I also had an encounter with it recently. What zou are going to do in order to delete is:
1.Look for all folders with shortcut arrow.
2.Right click then properties.
3. in the field TARGET delete everything before path to your usb (before eg. F:/Kobac usb).
4.Save settings. Open folder and copy it to harddrive
5. Do this for all folders.
6. When zou finish coping your data, format your USB.
7. To Format fo to My Computer, right click on USB and format.
8. Copy files from harddrive to your USB back
9. Enjoy!
Good luck, Kobac
May 24, 2011 | Computers & Internet
I have genuine windows 7 but computer says that it is not genuine
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B). Method A: Disable the Plug and Play Policy
1. Determine the source of the policy. To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to "Not Defined." Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy:
1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template
Query status
Enumerate dependents
Interrogate
User-defined control
Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)
(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)
(A;;CCLCSWLOCRRC;;;IU)
(A;;CCLCSWLOCRRC;;;SU)
S:(AU;FA;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;WD)
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to "SU" (SDDL_SERVICE - Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO's in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
  1. On the computer that is out of tolerance, start Registry Editor.
  2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions...
  3. If the NETWORK SERVICE is not present, click Add...
  4. In Enter the object names to select type Network Service and then click Check Names and OK.
  5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
  6. Restart the computer.
  7. After the restart, the system may require activation. Complete the activation.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 13, 2011 | Microsoft Windows 7 Ultimate 32 & 64 BIT
How to by-pass windows' screeensaver password
hi dear
in the login box
press ctrl+alt +del
fill user name : administrator
and left the passord blank
enter
oke
cropp
Mar 21, 2008 | Toshiba Satellite A60 Notebook
Microsoft Internet Explorer 7 Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
