Whirlpool side by side model GD5SHAXKQ00. The area where the water fills the ice tray (inlet) is frozen over. I can get water from the front OK, but ice maker won't make any ice.
changed over send recieve units to stop ice maker making ice as no light visible in display window....
(More)
changed over send recieve units to stop ice maker making ice as no light visible in display window. also found resister burnt out, but still no ice and flikering of displays. removed lamp solved solution for 1 night. must be some relay flickering as sounds like it all night long
Side By side. ED2FHEXMQ00. Will not Cool. Compressor clicks to start, runs for 15-30 seconds, then...
(More)
Side By side. ED2FHEXMQ00. Will not Cool. Compressor clicks to start, runs for 15-30 seconds, then clicks off. Will Cycle this way yet no cooling. Fan is good, Coils are cleaned and setting at mid point on both freezer and fridge side. Prior to loosing all temp from fridge, could hear the thermostat click in at current temp as adjusting. Is overload or capacitor a problem on compressor. Compressor does get hot as it cycles. Let it cool and back to start, stop. with no temp change. Thanks for any assistance.
An ice cube got stuck in the ejecter fingers. Once I removed it the maker has not restarted making...
(More)
An ice cube got stuck in the ejecter fingers. Once I removed it the maker has not restarted making ice. This has happened in the past and the icemaker continued to work after the stuck piece was removed.
