2004 Dodge Durango Logo
Posted on Feb 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 Durango 5.7 timing gear alignment
I need to know the correct timing gear alignment for my 2004 durango 5.7 hemi. Any diagrams would be very useful.
Anonymous
Level 2:
  • Expert 49 Answers
  • Posted on Feb 13, 2009
Anonymous
Expert
Level 2:
Answers
49
Questions
0
Helped
84508
Points
319
  1. If tensioner assembly is being replaced, install tensioner and mounting bolts. Torque bolts to 28 Nm (250 in. lbs.) .
  2. Retract tensioner if required. CAUTION: The camshaft pin and the slot in the cam sprocket must be clocked at 12:00. The crankshaft keyway must be clocked at 2:00. The crankshaft sprocket must be installed so that the dots and or paint marking is at 6:00.
  3. Place both camshaft sprocket and crankshaft sprocket on the bench with timing marks on exact imaginary center line through both camshaft and crankshaft bores.
CAUTION: The timing chain must be installed with the single plated link aligned with the dot and or paint marking on the camshaft sprocket. The crankshaft sprocket is aligned with the dot and or paint marking on the sprocket between two plated timing chain links.
I need to know, before I ask Good evening, how many oxygen sensors does my 2004 Dodge Durango Limited Edition w/hemi 8 cyclinder 4wd 5.7 engine
2004 Dodge Durango 5.7 Hemi has 4 oxygen sensors. Each bank has an upstream that's the newer style that controls more of the fuel trim than the previous type. The other 2 downstream sensors are for reading the after-cat A/F ratio and determining catalytic efficiency as well.
2004 5.7 hemi dodge durango.turns over but will not start
Basic testing needed. Spark at the plugs? Fuel pressure correct?
Which fuse is for the brake lights on a 2004 Dodge
Google search Fuse diagram for 2004 Dodge Durango Limited 5.7l/ Hemi look around if no answer look on the fuse box cover. Diagram usually located inside.
I NEED A DIAGRAM FOR THE 2004 DODGE DURANGO ENGINE 5.7
i need help putting on motor mounts for a 2004 dodge durango 5.7 hemi
7helpful
2answers
Need a belt pulley diagram for a dodge durango
  • This is the belt diagram for the standard 5.7 Hemi for the 2005 Dodge Durango. IF your engine is different then simply put the engine size donn in the comment section and I will return with the diagram.
  • Regards,
  • Tony
23helpful
2answers
I need a belt routing diagram for a 2004 dodge durango 5.7
Here's the standard belt routing for 5.7 Liter HEMI engine.
Please also check the under side of the hood and the radiator support area for the diagram.
1helpful
2answers
Need 2004 Dodge Durango Belt Diagram
Click on the following direct Link. It has several Diagrams including one on the bottom of the Links' Diagram Page for your Belt. Also is has several other very useful diagrams for your future use.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com
http://www.2carpros.com/car_repair_information/year/2004/make/dodge/model/durango/2004_dodge_durango_drive_belt_routing_diagram.htm
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
