Question about Microsoft Xbox 360 Console
GAMES/DVDS WONT PLAY
I TURN CONSOLE ON INSERT DISC,STARTS 2 READ THE DISC THEN NOTHING TELLS ME 2 OPEN UP DISC DRIVE.DO I NEED A NEW LASER UNIT
    Problem Solver:
  • 8 Answers
Most probably YES. Your xbox doesn't detect the disc because the laser can't read it. Either it is damaged or the disc is dirty or scratched. Try several disks, and if the problem persists then you'll know for sure that it's the laser unit.
If you found this solution helpful please rate it. If you need further assistance feel free to post a followwup comment.
Posted on Feb 13, 2009
My xbox 360 wont read the disc?
the laser lens needs clean, or adjusting which would require you to open up console and disk drive. there are 2 tiny screws on the lens which adjust for watching dvds and games the right hand side screws needs to be turned ever so slightly. or you may need a new laser lens all together. look at youtube for some help.
Nov 03, 2011 | Microsoft Xbox 360 Console
It says unable to read disc when i put the game in.
Please Rate me!
What Is It? The Disc Read error is a simple one. It simply means that the Xbox is unable to read the disc that you have placed in the drive. In the majority of instances, this error has nothing to do with the functionality of the console, but, rather, hinges on the actual disc that has been inserted into the DVD tray.
Disc-Related Errors The most common reason for Disc Read errors are related to the disc itself. Numerous conditions can keep the laser from reading the information contained within the game, DVD or CD in the DVD drive.
  • The disc is scratched - Game discs, audio CDs and DVDs can become scratched very easily. Usually this is because they have not been kept in their cases, but left in the open. Simply resting two discs atop one another can scratch the bottom disc. If discs are sufficiently scratched, the data contained on them will be inaccessible to the drive.
  • The disc is dirty/dusty - Dirt and dust can build up on the faces of discs left exposed. When sufficient dirt or dust has built up, it can block the laser beam used to read the disc, resulting in a Disc Read error.
  • The disc is the incorrect region - DVDs come in formats called "regions." These regions match the region specified in the software of the DVD player. Some games also have these regions. If the region of the DVD and that of the player do not match, the disc will not play.
Can I Fix These Errors? Repairing disc-related issues may or may not be possible. If the cause is simply dirt and dust, you can certainly repair the disc. However, if the cause is due to extreme scratching, then replacing the disc is likely your only choice. If the disc is from the incorrect region or from another country, you will have to obtain the correct region. Returning the disc to the retailer for exchange may work.
Non-Disc Related Errors As mentioned, there can be some Disc Read errors that have nothing to do with the disc at all. In this case, it's time to troubleshoot the Xbox.
  • First, simply try to reboot the machine. Often, this will flush the cache or other error and allow the game to operate or the disc to play.
  • Second, try removing the hard drive and/or memory units. Once removed, reboot the console and attempt to load the disc with the hard drive and memory out of the unit. If this works, you can simply shutdown and reinstall the hard drive.
  • Attempt to play the disc in another type of player. For instance, attempt to play the DVD in another DVD player or the CD in a CD player. If the disc plays in these players, you may need to clean the Xbox DVD player.
  • Check to make sure that all air vents are open and are able to provide sufficient airflow. Overheating can cause Disc Read errors, as well. In addition, ensure that the power supply is unobstructed and uncovered. Much like the Xbox 360, the power supply can become quite hot and can cause errors if unventilated.
  • Check for disc tray errors. Depress the eject button and watch the tray extend. If the tray partially extends and then retracts immediately, you may have a problem with the DVD drive. If your Xbox is under warranty, this can be replaced at no charge. However, if you are out of warranty, you can install a new DVD drive on your own.
  • As a note, make sure that the new DVD drive comes with the same firmware as your original console, or you may experience additional error codes after the installation of the new DVD drive.
May 09, 2011 | Video Game Consoles & Games
When i insert a video game into the console it doesn't read it just tells me to open and close the console what could it be?
You may have noticed that this has happened over time, and you play video games much more than you play dvds. Here are some steps you may trouble shoot with:
1.Try rebooting the system
2.Try updating the firmware by simply connecting to the internet.
3.Try oiling the gears inside the disc drive, without opening the cover, stick the oil inside and squirt. The gears might be sticky.
3.If the above solutions did not work unfortunately, your laser diode for reading Game Discs may have burned out. Try taking it to a store, which fixes video games consoles near you. Ask to either replace the laser diode, the whole disc reader all together, or to try pot calibrating the diode.
Dec 21, 2010 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Ps2 wont play DVDs
Your PS2 laser is wearing out. When the laser starts to go, first games will skip... then eventually the PS2 will stop reading DVDs altogether. If you keep using it to read CDs, it will eventually stop reading those too and the laser will die altogether. Here's a website that will help you identify your PS2 model, show you how to replace the laser, and they sell parts and do repairs too
http://store.richspsxparts.com/slps2direerl.html
Oct 05, 2009 | Sony PlayStation 2 (PS2) Console
My ps3 dosent read any discs
Hi my name is Juan an ps3 expert and this is what your problem is your bluray laser has stopped reading disk ,dvd bluray movies and games some lasers they still play regular dvds but not games some lasers play nothing and this is your case but don panic it can be fix you fix it your self or have someone fix it for you another laser will cost you around 65-75 depending on what model you have there is 2 different types of laser I can help you figure out which laser you have in the back of the unit there is a white label with the serial # and after the serial # is the model # it start with CECH--01can you please tell me what are the other two missing numbers between the H AND 01 look on your label and let me know this way I can tell you which laser you need to buy or if you want I do fix ps3 I do sell ps3's and parts on ebay I am a trusted power seller my Id is flacooo1 you can let me know here or on ebay which model # you have thanks and good luck
Apr 29, 2009 | Sony Playstation 3 (PS3) Console
Disk drive wont read
you may need a new disc drive or you may just need to clean the laser in it.
if you remove the disc drive and turn it over you will see the laser, just clean it with a non static cloth.
Mar 11, 2009 | Microsoft Xbox 360 Console
Not reading
Your laser has probably gone bad. You will need to have it replaced. Either the whole drive or the laser. Check your local game stores to see if they offer repairs such as that.
Nov 23, 2008 | Microsoft Xbox 360 Console
My xbox turns on but wont read discs or dvds?
your dvd drive is broken. Thats what it sounds like to me. It cant be fixed you need a new xbox sry
Apr 04, 2008 | Microsoft Xbox Console
Xbox360
will your console read dvds if it wont read a dvd that means your laser went out and you need a new laser for the dvd drive a way to tell is if is a laser problem play a cd if it works and dvds dont you need a new laser or you need to calibrate the laser
Dec 29, 2007 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
