Question about Vacuums
Could you please send to me the crevice tool for this vacuum and the instructions manuel for this model: Sanyo SCX1000P Powerhead Canister V Denis Lebel Norton Country store RT 114 Norton VT USA 05907 Thanks so much Denis
  • 217 Answers
As far as the Manual is concerned it can be downloaded from: Sanyo SCX1000P Manual
Posted on Feb 13, 2009
  • Saroj Sharma
    Saroj Sharma Feb 13, 2009
    and you can purchase the tools from http://www.shopping.com/xDN-vacuum_clean...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
This site is a community to assist users with technical problems. It is not affiliated with any particular brand nor could it directly supply components/tools as per your post.
You would be better to contact SANYO Fisher Service
800-421-5013
Monday - Friday, 7:30AM - 5:00PM PST
Good luck and thank you for using FixYa.
  • 495 Answers
  • Vacuums Master
  • 19,396 Answers
The crevice tool that was provided with the vacuum is only distributed by Sanyo.
You need to contact Sanyo to get a replacement.
How to attach crevice tool
Hi! Below is step-by-step instructions for attaching your crevice tool.
1. Place unit in an upright position. Push release button forward, then pull handle from unit.
2. Remove floor tool from nozzle.
3. Attach crevice tool by inserting into nozzle. To remove gently pull apart.
Hope this helps out!
Apr 26, 2014 | Dirt Devil Simpli-Stik 3-in-1 Bagless...
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
No power when its turned on
There was a (common cause) power arc during the swap (while running the vacuum).
The fuse located under the grey clipped-on plate of the canister is blown. The fuse is soldered-on the board and would need to be changed (board or fuse). Not "user friendly" zone. Warranty? Smart if they designed a breaker button instead of a fuse here...
Rick
Mar 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
I need a owners/instruction manuel
Go to www.feinus.com, click on tool diagrams, scroll down to your vacuum model no., click again, and your manual appears in PDF format. Good luck
Jul 14, 2008 | Fein 9-55-13 Turbo II Bagged Canister...
No power in power nozzle
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=493359
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
181 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
