Question about Xerox Office Equipment & Supplies
E2 Error code on Xerox XC1875 Copier
I get this error occasionally when attempting to make a copy. The instructions say to lift the cover and clear a jam, but there is no jam. Usually, lifting the cover and closing it causes the problem to go away. I cannot find a service manual for this copier on the Internet or via Xerox. Any help will be appreciated.
    President:
  • 2,072 Answers
Most likely the paper feed rollers are slick and simply not feeding paper. You can google a business called "the parts drop". They have an excellent site and parts availability.
Posted on Feb 13, 2009
Getting an H4 Error code on my Xerox XC1045 copier. Any Suggestions?
This will most likely clear it. If not then the heat rod in the fuser most likely went bad.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. Program the copier as if you were going to make 14 copies.
  7. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  8. Run a test copy.
  9. repeat 1-7 more than once to be sure it has worked properly.
There was incorrect info in this I copied and pasted. I corrected it.
Feb 23, 2010 | Xerox Office Equipment & Supplies
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Xerox XC1875 U4 Error on Startup
Give this a try. it may clear you code. Use program 14
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
May 04, 2009 | Xerox Office Equipment & Supplies
Error message shows e2 but there isn't a paper jam anymore
Hello sir; try to turn off the power and turn on, if still don't work, you have to check the sensor it located where the paper got jam,
Jan 10, 2009 | Xerox WorkCentre XD120f Copier
How do ya reset fuser code (H-4) Xc1044 Xerox?
  9. Run a test copy.
Nov 26, 2008 | Xerox Office Equipment & Supplies
Xerox workcentre xd105f
It is entirely possible you have a small piece of paper that got ripped off somehow and it is now blocking the sensor leading the machine to think it has a paper jam.
Follow your jam clearance instructions again and pay close attention and rotate all movable parts in the jam area many times, then reboot the machine multiple times and allow the machine to completely come up before rebooting again, it may be necessary to reboot the machine 3 or 4 times to clear this error, each time following the jam clearance, if this doesn't resolve then you should have an expert take a look at the machine.
Oct 19, 2008 | Xerox WorkCentre M123 Copier
E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Apr 14, 2008 | Xerox WorkCentre XE80 Laser Printer
Error code H3 displayed on Xerox XC1044 Copier
this is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
Mar 15, 2008 | Computers & Internet
213 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
