FixYa.com
Tags:
Kaz Heater
Vectra starting problem
By Bray - usenet poster
Hi ,
I have a 2003 vectra 2.0tdi , very occassionally when starting it fires
then instantly dies then it takes ages to restart , when it eventually will
restart " 10 mins or so " it starts in a big cloud and black smoke and
starts very rough for a few seconds ?
Anyone any ideas please
Thanks
Kaz
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
Helpful (85)
Peter1
Peter1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had a similar thing with my Astra 2.0 DTi... turned out to be the fuel
return pipes which were
replaced under warranty.
Could be the glowplugs though...
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
Thanks Alan , yes im waiting till the glow light goes out and only have
clutch pedal depressed as the manual says , the car is under warranty but
will they look at it with being such an intermittent fault ?
Kaz
Solution #3
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
It sounds to me like a glow plug issue. Are you waiting until the
pre-heater light goes out before starting? Also, are your feet off the
pedals when you turn the key?
Either way, your dealer should be able to sort it easily.
Alan
Can you Help with these Heaters problems?
Heaters
ROCKER SWITCH DIAGRAM
i need to see a wiring diagram... Answer This...
Kaz Heater
vauxhall vectra
windscreen jets not working Answer This...
Kaz Heater
vectra 2.0 sri
Hi can any one help when i put... Answer This...
Kaz Heater
vectra has really bad problem...
starts after a battle ticks... Answer This...
Kaz Heater
vectra 2001 2.0dti
does not start checked fuel at... Answer This...
Repair Service
Find Heater Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
