Question about Mintek DVD-1600 DVD Player
Setting up mintek 100 dvd player to cable box to tv
I cant figure out how to set up my dvd to my philips hdtv
  • 3 more comments
  • sam4cee Feb 13, 2009
    plug in outlet color orange for coaxil cable. its a mintek 1600 dvd. the tv is a philips hd 1080d flatscreen. i just got a cable box for hdtv and the dvd doesnt have the usual plug in for the cable wire. i was going to go from the cable to the dvd to cable box to tv. buy the way i am a woman so i am going to need help for dummies.
    there will be no surround sound. i was also going to throw an old vcr into the mix for my grandaughters tapes.
    tv model phillips 47pfl3603d
    cable box scientific atlanta explorer 4250hdc
    mintek dvd 1600
    thank you for talking slow for me...
  • Mark Egan May 11, 2010
    OK, I'll use my "directions for a woman" voice. :-)
    Give me Model number of the TV, and the cable box, so I can see what connections you have available. I don't think we will daisy chain the unit's together like was done with a VCR in the past (Antenna to VCR, then VCR to TV).
    We will probably set the VCR on one input, the DVD on another, and the cable box on another. Or we may daisy chain one or two together. But I need to look at the connections.
    What outputs do you have available on your Mintek, and what inputs do you have available on your Philips TV?
    Will a cable box be in the loop?
    Will there be a surround sound receiver in the system too?
    Problem Solver:
  • 15 Answers
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Posted on Mar 19, 2009
  • InSub Beckley
    InSub Beckley Mar 19, 2009
    I forgot to mention the RF OUT. It looks like an S-Video output, but do not be fooled. This is apparently a special jack for a Mintek RF Adapter used to hook up the DVD player to an older TV that only has the Cable/Antenna connection which requires RF modulation. You can use any of the other outputs for any RF Modulator for such a TV.
How can i hook up my player to my tv with no rca inputs
There are adaptors. I bought a Philips brand that allows any dvd player to be connected to any television. You connect the RCA cables to the Philips adaptor from the DVD player then you connect the Philips adaptor to the rf input of the television with a coaxial cable.
Nov 07, 2010 | Mintek DVD-2580 DVD Player
Mintek Portable DVD Player
On your TV IN .. Yellow is Video, Red is 1 Audio. White is Audio 2 this is for Stereo if Mono white is not used.Your TV then needs to be set to Aux or Imput.If no button on TV use UP-Down Chanels. Good Luck.
Sep 05, 2009 | Mintek MDP-1760 Portable DVD Player
Audio too low
Clean / Check the RCA patch cord.
Use another set to troubleshoot this connection problem.
Check output limit dial/setting on DVD unit.
Adjust TV volume?
If you are using S-VIDEO cable......check for bend pins inside the connector.
Jul 15, 2009 | Mintek DVD-1600 DVD Player
Connect Portable DVD Player to TV issue
try to change the connection of the video.insert the video plug to yellow colored jack, tv and dvd.
May 17, 2009 | Mintek MDP-1020 Portable DVD Player
Mintek DVD-1600 Setup to cable box/tv
A dvd player that doesn't record hooks straight to the television, not the cable box. Tv's typically have av jacks. If yours doesn't, you will need to buy an rf modulator. If your tv has the jacks, U will need to use your tv remote and hit tv video or input or source on that tv remote to switch between input and tv modes.
May 03, 2009 | Mintek DVD-1600 DVD Player
Mintek Passwords
I believe the password code is 88888. This is factory set this way and can be changed
Oct 20, 2008 | Mintek DVD-1600 DVD Player
Mintek 2110 no component video
You need to change the Video out in the menu.
Press set up on the remote
move down to video out and select YUV output
it should now work
Aug 08, 2008 | Mintek DVD-2580 DVD Player
How do I get my play station 3 to work on av 4 componet video inputs?
The simplest solution is always the easiest to try. Unplug the video cable of your dvd player. Plug your PS3 video cable in and test.
Jan 05, 2008 | Philips 55PW9363 55" Rear Projection...
Unable to watch DVD's on this TV
Your DVD player may be set up to put out a different mode. Are you using the component cables or s-video? If it's the component cables, make sure you're player is putting out 480p. Also, try it with another set to see of you can localize the problem.
Jan 02, 2008 | Philips 60PP9202 60" Rear Projection...
Need help conecting cords to correct locations
there's a red and white cord at both ends 1st set in dvd, my ? is
where do the other red and white cord go into the tv or cable box
Dec 27, 2007 | Mintek DVD-1600 DVD Player
Mintek DVD-1600 DVD Player Logo
343 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
