Question about Vtech V-Tech VT-9162 900 MHz Cordless Telephone with Three Mailbox Digital Answering System ( VT 9162, VT... (VTECHVT9162900MHZCORDL)
Calls don't come through
Anwer the phone and no one is there, it rings but no one can call in, no problems calling out
I had similar incident with my office phone and the cord was put in the wrong jack on the phone, have you looked at that?
Posted on Feb 13, 2009
My iPhone 3 don't ring when I get a call
First you should check ringing volume, incoming call alert type... If these are ok, you have got problem with your ringer...
Sep 23, 2011 | Apple Cell Phones
I have the panasonic phone but when someone called me after 3 rings it goes on answering machine. i wanted to make it longer at least after 5 ring. please help me with any suggestion.
You can set your ring time to 5, 10, 15, 20, 25 or 30 seconds.
  • Tap **61*121*11* into your phone as if you're making a call.
  • Next enter a time between 5 and 30 (the number of seconds in multiples of 5)
  • Press # and then the call button. Don't put the phone to your ear - just look at the display until you see a message confirming your ring time has been set.
For example, **61*121*11*25# followed by the call button would set your ring time to 25 seconds.
Jun 11, 2011 | Computers & Internet
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
May 11, 2011 | Panasonic KXDT333 Phone
Not receiving any incoming faxes
Is the phone line working? Do you have any devices connected to the phone line that pick up before the fax machine? Make sure the machine has paper and is set to FAX or AUTO. Is there a Memory Full error? Clear the memory (Setup > Memory Clear then press Start/Enter. Use the left and right arrows to select the items to remove. Press Start/Enter twice (second time to confirm the choice). Repeat until all memory is cleared that you wish to clear. Then press Stop to exit.)
If you are using the ANS/FAX mode and have an answering machine connected to the extension port, disconnect the anwering machine and switch to FAX or AUTO. Check if the machine receives faxes. Sometimes the extra device causes interference. Call the fax machine from a different phone number and see if you hear the fax tones.
Check that the Junk Fax barrier is off, if the incoming call is from a machine that is not listed in your speed dial database. If you have a distinctive ring, make sure that the Fax machine has learned the ring by pressing Setup go to DRPD. Choose Set and call the fax machine from another phone. The LCD will say Waiting Ring until it gets that call and then once the ring is learned will say END DRPD Setup
I hope these ideas help.
(If you have a phone company voice mail service, the faxes may end up stuck in that box. It depends on how many rings the fax is set to wait before picking up versus when the voice mail opens to take the call.)
Jul 16, 2010 | Samsung SF-515 Plain Paper Laser Fax
PIXMA MP780 will not receive fax with Verizon DSL connection. Before unit was ok with comcast cable, Note: I'm able to send fax. RBRANT
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
May 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Screened calls
go to menu >settings>call settings>no. Screening>select the number which you don't want to be screened
Apr 12, 2009 | Nokia 1600 Cellular Phone
My phone dosen't ring
Factory diagnostic was defective phone.
Mar 25, 2009 | Thomson Lands Phones
Panasonic kx tg5571 phone drops all calls after first ring
I have the Panasonic phone system Mod. # KX-TG5371. My calls, in and out drop out after 1st ring often. Whats going on.
Don
Dec 29, 2008 | Panasonic Phones KX-TG5571
HP 1040 "JUNK " FAX MACHINE
can hp 1040 fax transfer printed copies to hp pavillion note pad
eadyj1948@yahoo.com
Apr 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Call answering
sir just try to reset the phone somtimes its just the settings errror. just go to menu, settings, master reset, reset settings. ok! hope it will solve your problem...
peace!
Nov 25, 2007 | Nokia 6111 Cellular Phone
Lands Phones Logo
79 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
