Question about HP OfficeJet 6110 All-In-One InkJet Printer
Itech Bluespeak.. Car Bluetooth Kit
The problem is that when i connect it with the Ciggratte Charger in ma Car .. Nothing Happens, No light appears and no connection in found.. It is new and just taken out from BOX... What cod be the error .. Also if anyone can give me the link to download the MANUAL for the product..
THANKS!
  • 1 more comment
  • Hash 1234 Feb 13, 2009
    the cigratte lighter accroding to me ios fine becoz I can light up ciggratte with it.. the bLUETOOTH ONLY DOESN'T WORK WITH IT ..
    Hmm .. I think i won't be able to retun it .. Uncle gifted it to me several months back.. I aint got the reciept and fingy .. IS there any possible solution or repair ??
    the charger is attached with the device .. the name is ItechBluespeak .. No model is written .. U'll find it with the name on internet ..
  • 21 Answers
There could be a lose wire in your car. try using a different cigarette lighter to test out whether its a lose wire or your charger!
Posted on Feb 13, 2009
  • Brian Cruz Feb 13, 2009
    I think you should return it and get a new one. There might be something wrong with the charger.
    Well try and shake it to see if you get a light on the charger and also what is the model of the charger.
I need a manual for the i-tech carkit 305
The only serious reason you need the manual is because, I guess, you need to know how to conect the bluetooth of your mobile to the "i.tech carkit 305" device. If so, the answer is the following:
You simply keep the green button pressed in order to see the following lights: 1) blue, blue, blue... 2) probably purple... 3) blue red blue red blue red
Just right now (when blue and red colors change) you search in your mobile for new devices and after you find the "i.carkit 305" you immediately connect with it.
Enjoy it now!
Athan D.
Jun 20, 2011 | Dynamic Itech Itech ICar Kit 305
My iphone 4 will not connect to the ck-20w handsfree kit
I had the same problem. The solution was to reset the settings on the car kit. Switch engine off ensure no light on car kit control dial. Now push main dial in and hold for 10 seconds. Blue light will appear in car kit control dial. Now try and connect your iPhone. It worked for me, however callers do hear a bad echo when they talk to me. Hope this helps.
Feb 28, 2011 | Nokia Ck 20w Multimedia Handsfree...
When turning the bluetooth on my iphone cant find the parrot minikit, but my old nokia had no problem, is it the iphone or the parot?
Press and hold both the red and the rotary buttons for some 3 seconds, until the indicator light flashes alternately in red and green. It is in pairing mode now, thus visible for other devices, for the next 3 minutes. Then, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '1234'. If the pairing process is successful, the car kit should sound a beep. By the way, if your car kit's user guide happens to be missing, feel free to download it from this location. You will find many details about settings for your car kit there.
Please, let me know if I can help you any further. Regards, Carlos
Nov 19, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
I have a parrot CK v3.13 bluetooth car hands free system. Works fine with my Nokia. I have changed phones and now paired my iphone 4 with the parrot CK v3.13 successfully but do not have any volume...
Nov 16, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Need to connect my new Motorola cell phone to my bluetooth
You must put your car kit in pairing mode prior to pairing it with your phone. If it has never been paired to another device before, just by turning it on (i.e. pressing and releasing the microphone shaft), it will enter the pairing mode, denoted by the indicator light flashing alternately in red and blue, right away. In case it has been paired before, or, rather, it refuses to enter that mode automatically, you must force it into that mode, by pressing and hold the accept button whist turning it on. Anyway, once in pairing mode, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or passcode) is requested, enter '0000' (four zeros).
By the way, detailed instructions on how to pair it with your phone (illustrated with pictures) can be found on its user guide; In case yours happens to be missing, you'll still be able to find it here.
Hope you are able to sort your problems out soon.
Regards,
Carlos
Nov 12, 2010 | Blueant Supertooth Light Bluetooth Speaker...
How do I pair my PArrot Minikit to my mobile phone?
Oct 14, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
SUDDENLY THS MORNING THE BLUE LIGHT ON AND THE RED LIGHT OFF ARE FLASHING ALTERNATELY IE WHEN AERIAL LOCATED TO ON POSITION THE ON LIGHT BLUE FLASHES ALTERNATE RED AND BLUE AND BLUE TOOTH NOT WORKING
I think your car kit has lost its pairing data. Blue and red lights flashing alternately means it is in pairing mode. On your phone (or the device it was paired with), delete the partnership with your car kit, and make it search for new devices again. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or passcode) is requested, enter '0000' (four zeros).
Regards, Carlos
Sep 03, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Pair parrot minikit 1.03C with my iPhone 4
Aug 26, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
I have a parrot minikit 004nyca0423 how do i get or reset my passcode for this
Its passcode is hardcoded to '1234'. Anyway, to pair it with your phone, press and hold both the red and the rotary buttons for some 3 seconds, until the indicator light flashes alternately in red and green. It is in pairing mode now, thus visible for other devices, for the next 3 minutes. Then, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '1234'. If the pairing process is successful, the car kit should sound a beep. By the way, if your car kit's user guide happens to be missing, feel free to download it from this location. You will find many details about settings for your car kit there.
Regards, Carlos
Jun 03, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot minikit
Most probaly, yes. I don't have an iphone to either confirm or deny it, but, I can see no reason at all why they would refuse to pair to each other. To do it, press and hold both the red and the rotary buttons for some 3 seconds, until the indicator light flashes alternately in red and green. It is in pairing mode now, thus visible for other devices, for the next 3 minutes. Then, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '1234'. If the pairing process is successful, the car kit should sound a beep. By the way, if your car kit's user guide happens to be missing, feel free to download it from this location. You will find many details about settings for your car kit there.
Jul 20, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
