Question about Goodman Heating & Cooling
Keepe shutting down the heat.
This is a 5 ton paCKAGE UNIT FEEDING 1200 SQ F APT. CHANGED THERMOSTAT TWICE SOFAR .
  • Mark Egan May 11, 2010
    Please reply what the symptoms of the problem is, and give more detail as to what the unit is (Model number, split system, heat-pump, gas furnace, etc.).
    My initial thoughts are a 5 ton unit is oversized for 1200 sq. ft. for cooling (unless you live with the doors and windows open and are near the equator.).
    Scholar:
  • 140 Answers
Mark is right 5 tons is way too big and you are probably icing up. Even here in Az we size units to no less than 500 sq. ft. per ton and more like 700 sq. ft. per ton. What is the make and model number of your unit? I'm a Goodman Authorized Contractor so I should have most info on hand.
Posted on Feb 13, 2009
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
I have some heat, burners on, is there a way to get more heat air filters clean i dont know what to do
If you are using a pleated or high efficiency type filter, that is a problem, the high efficiency filters
actually restrict a great deal of airflow, a AC unit requires 500 cubic ft per minute of airflow per ton of refrigeration capacity, 500 sq ft of home per ton generally = 1500 sq ft home has a 3 ton unit or needs 1,500 cfm of airflow, both in heat and cool modes, Honeywelll Enalysises prove these filters even when new reduce up to 500 cfm of airflow, effectively making a 3 ton system a 2 ton in output due to airflow restriction, try removing that filter with the fan on, it likely is pulled in sold with a huge pressure drop caused by tj filters obstuctive flow capabilities.
And 755 of all A evaoprator coils have been plugged or restricted by dust , dirt, oils from cooking, cigarrettes, running with no filter etc, a chemical cleaning of the evap coil above the firnace, or brlow it is indicated as a possible issue. Use the cheap 99 cent seee through filters we used to use
Dec 27, 2010 | Honeywell Programmable Thermostat Heater
Does not seem to be sufficient cool for a 1600 sq ft manufactured home coming from the Coleman unit installed. Some vents more air, others less air. Unit runs without stopping ever. Can you give us some...
Hi John, depending on the size, I would need the model number from the outdoor unit if it is a split system, you should have 400 cfm per ton of cooling. If you have a 1600 SQ' home, and a 3 ton unit, 3 x 400 cfm is 1200. It would be to small. There are 12,000 B. T. U.'s of cooling per ton. 2 tons would be 24,000 b t u's. 3 tons would be 36, 000 b.t.u.'s. Also, most contractors put lever dampers in the duct work that can be adjusted. They will put a red flag where the lever is and we can adjust the flow to balance out the house. I don't know where your ducts are, under or above, but with a good light find the crawl space and check it out. Get the model number and call it in to get the tonnage or send it to me and I will tell you. It will have a 024, 030, 036, 042, or, 060 in the number, MODEL number and figure like I told you above, 12,000 per ton. 060 would be a 5 ton. This will let you know if the unit is the right size or not. Please rate me on this and I know you will be kind. Thank you John.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS CFM is cubic feet per Minute.
Aug 05, 2010 | Coleman Heating & Cooling
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
How much area can 1hp of this brand can cool
the 'rule of thumb' is 1 ton of AC for every 600 sq feet of a well insulated space (400 sq ft if not well insulated)- for example if the space to be cooled is 1200 sq ft - and is well insulated - you would require a 2 HP unit. 1200 divided by 600 = 2
if the space was not well insulated - you would require a 3 HP unit. 1200 divided by 400 = 3
note; 1 ton of air conditioning - is sometimes referred to as 1 HP or 12000 Btu. Whether you call it 1 HP or 1 Ton or 12000 Btu - they all three mean exactly the same thing.
take this example - 2 tons of air conditioning can also be referred to as 2 HP or 24000 Btu.
fyi - it doesn't matter what 'brand' - they all work off the same principle.
hope this helps
Jun 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
I have a GE model No. BTN 748A100A1 (central air outside unit). Serial number 40564128. When was it made? What is its efficiency? It now handles #1950 sq. ft. Cab it handle 2950 sq ft when I remodel?
GE stopped making AC units probably 20 years ago. The same unit will not handle an additional 1000 sq. ft. I believe it is a four ton unit and about a 6 SEER rating which is way down on the efficency scale. You will need a 5 ton system to handle 2950 sq. ft. The average SEER rating now is 13.5.
Oct 07, 2009 | GE Heating & Cooling
Heating & Cooling Logo
122 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
