Question about HP Pavilion MX75 17" CRT Monitor
Hp pavilion mx 75 monitor displays a flat line across the screen
Is there a way to correct this?
    Scholar:
  • 87 Answers
A flat line in the picture is caused by a broken yolk or bad fly back transformer. This is a expensive fix. I would think that purchasing a new one would be several hundreds cheaper.
A mx 75 is a pretty old monitor. If you must have a crt (graphic artists or print artists do usually since they produce mostly correct color) You can pick up a new one from many of the local office supply stores or walmarts for under 100$ in the 17 inch range. I would however suggest a LCD for its power saving ability though. You would be suprised how much power those old crts use.
Sorry I couldn't be a better new bringer
Posted on Feb 21, 2009
  • 679 Answers
The life expectancy is about 5 years. You can fix it, but it's not worth trying to track down the power board for a crt, it's going to cost you more than a new monitor. There are flat panels for under a hundred dollars now, you will save that on electricty over a two year period. Although some folks just like them better than lcd's that is no longer an issue, with the faster resolutions in the past few years you will be better off going for a new lcd. HP's website is the most likelly place to obtain service for your monitor, but I just got an email from Dell this morning and you can get a new 19 inch for about a hundred dollars from their reurbished shop if you really want to save some money, and a 24 was only around $200.
Posted on Feb 20, 2009
Pavilion dv4 display horizontal flashing lines across the lower screen in taskbar area
I'm Sorry to say but it could be that you need a new screen (easy repair around $195) unless you go to HP
Or it could be the built in video card (much harder to repair)
Do the lines appear from start up or slowly get worse as the comp gets hotter, if this is the case it is more likely the video card then I would contact HP to get a quote, But first,
Try plugging your laptop into an external monitor & see if the lines show up then
Nov 26, 2013 | HP Pavilion dv4000 Notebook
Monitor only works at start up. then I must use optional monitor. occasionaly monitor will work for a short time
You may need to change the resolution on the screen, in windows, you may find the "Display Options" under "Control Panel", usually this problems is caused by the computer having a hight resolution than the supported by the monitor, for your specific monitor the available resolutions are:
Support of video modes up to 1280 x 1024 at a 75 Hz refresh rate from the manual at:
http://h10032.www1.hp.com/ctg/Manual/c00264775.pdf
That means you have to chose a resolution lower than 1280 x 1024 and a frequency lower than 75 Hz. Anything higher than that on the resolution or frequency will cause the monitor to display a "Out of Sync" message and turn off shortly thereafter.
Thanks !!!
Mar 06, 2011 | HP Pavilion F1703 17" LCD Monitor
My HP Pavillion M70 monitor is saying "video cable connected?" when I try to use the monitor. I am trying to output my laptop to the monitor because my laptop screen is wearing out, but I cannot get it to...
go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located at the lower left of the keyboard, normally between the CTRL and the ALT key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5, Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations with the age of the laptop and not all manufacturers have standardized on a key combo across the whole range, but you can usually figure it out from the little graphics on the function keys that line the top of the keyboard.
Aug 25, 2010 | HP Pavilion M70 17" CRT Monitor
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 flat screen monitor dimmer with grey lines
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor display is sideways not vertical
with some graphics card you can rotate the display try pressing ctrl and the alt key at the same time and while doing this hit the arrow key (or direction) that u want the bottom of the screen... so if u want ur screen upside down, hit ctrl alt and the up arrow
Aug 13, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
HP MX 75 CRT monitor just quit working. No light on the on button.
...strictly as, at at best. a long shot: according to a post I just read somewhere online about this HP MX 75, pressing AND HOLDING the + button on the monitor front and at the same time turning the monitor on and off repeatedly, may fix problems with this monitor.
Mar 18, 2008 | HP Pavilion MX75 17" CRT Monitor
Black horizontal line
The LC display is bad. The monitor will have to be replaced.
Jun 24, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP Pavilion MX75 17" CRT Monitor Logo
269 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
