Question about Ruud Handler Air Conditioner
Firebird 90-120 not starting after it ran out of fuel
Firebird 90-120 refuses to start after ran outof fuel. Refilled tank but it seems kerosine can't get to burner, is there a simple solution to this problem?
  • slokharold Feb 14, 2009
    Thanks thejet,
    i tried it but still no action? Kerosine doesn't make it's way to the burner! Could there be an air lock? What can I do to get the oil running?
  • slokharold Feb 15, 2009
    thanks, I think problem was the distance between fuel tank and burner and the fact that tank is in same level as burner! It's working again, thanks for your advice!
  • 15 Answers
On the lh side of the burner, there is the pump if you could look at it straight on there is 4mm allen screw at about the 2 o'clocl on the face of it, usinging a allen key loosen this then with the heating switched on, press the red reset button on the burner (round with red light) and the burner should run, where the screw is loosened you should see the oil bubble out, the run freely, the burner will fire, quickly tighten the screw back in. you may need to repeat to get it to work
a container under where your doing this will help
Posted on Feb 14, 2009
Testimonial: "cheers dude"
  • THEJET Feb 14, 2009
    you may have to do it several times to get it to come thru
My 98 firebird ran out of gas. now it want crank. what do i do?
You have likely burned out the electric fuel pump, when you run out of gas or run it below 1/8 tank it overheats (the gas cools and lubes the fuel pump) the fuel pump inside the gas tank and it seizes up, no fuel pressure not start.
Nov 05, 2016 | Cars & Trucks
Car is 1994 firebird with 3.4.Ran when parked but now turns over and hits trying to start but goes to backfiring and wont start
Try spraying carb cleaner in throttle body , see if starts ! Do you have a security light on the dash ? How many miles on it ? And is the spark happening at the right time ? jumped time , timing chain !
Mar 25, 2015 | 1994 Pontiac Firebird
2002 Pontiac Firebird acts like it ran out of gas and now won't even start. Could it be fuel pump or something else. Service engine soon light also comes on occasionally due to emmisions sensor fr
with the key on engine off listen to fuel pump,if you can not hear the pump winning ,the pump is bad
if you can hear it,it might be working but create enough pressure
you can rent a fuel pressure gauge from auto store and check the fuel pressure
Apr 19, 2013 | 2002 Pontiac Firebird
My 93 firebird starts but sputters and dies
I agree with Dennis on checking the fuel pressure.
Could be a bad pump, restriction in the tank, vent problem in the tank, bad fuel filter, or bad pump relay.
Jun 27, 2012 | 1993 Pontiac Firebird
1995 Firebird After Running Low on Gas
You have most likely sucked residue in the bottom of the fuel tank into your fuel filter, This can cause it to get blocked, Try fitting a replacement fuel filter as it's most likely it's never been changed anyway.
Mar 10, 2012 | 1995 Pontiac Firebird
Have misfires on firebird hestation and acting
could be fuel pressur regulator or coils
Apr 12, 2010 | 1994 Pontiac Firebird
2002 firebird ran out of gas, put in 2 gallons,won't start. Turns over and fires a little.
Takes a long while to get from tank to engine, and then it can flood out easily. Next time don't run out!
Jan 12, 2010 | 2002 Pontiac Firebird
MUTIPORT FUEL INJECTION PONTIAC FIREBIRD 3.1
My 92 Bird with the 3.1 did the same thing after it sat for about 2 months. The car had aways started right away before. I had to jump start it and I thought it would never start.Same as yours after it started. Seem to get better after I ran it awhile. It was getting good spark and was getting fuel. I checked fuel pressure, it seemed to be within specs.then it started to sputter and the pressure dropped to almost nothing. Seems that the fuel pump was going bad, but still would pump enough fuel at times to run. When the car was parked the fuel pressure would bleed off, and when I tried to start it the pump had trouble pumping enough fuel to pressure the system.Long story short! Replace the fuel pump, and filter.....
Mar 29, 2009 | 1990 Pontiac Firebird
Heating & Cooling Logo
1,663 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
