Question about Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T...
Tank keeps filling
I cant get the tank to fill after a flush. It seems like a pin or something in the power flush 2 assembly does not always seat again after a flush. The water just keeps running. This has been a problem from the beginning but is getting worse.
If it's a Turbo Flush 2 block in the water wait for presssure to bleed down and the top section (cap) you can turn counter clockwise this will release the top section. In the top section that comes off there is a black rubber seal, replace it (any hardware store) and this should fix it. That's about the only thing that goes wrong with them.
Posted on Feb 13, 2009
How do I get the water to stop filling the tank on my toto ST794S toilet?
there should be a screw adjustment on the ballcock or fill assembly...screw that down some to adjust...that regulates your tank water level....that screw goes in or out to adjust...one or other should do the trick...may have to do this a few times to get proper adjustment...good luck..
Jul 07, 2014 | Toto St794s-12 Nexus Tank With G-max...
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Home
Heater keeps shutting off what could it be cant find manual to help
Use this manual to assist you in troubleshooting. http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual will help you isolate the problem.
Things than can cause your symptoms:
1. Pump pressure incorrect
2. Dirty air intake, air output
and/or lint filter
3. Dirty fuel filter
4. Obstruction in nozzle
5. Photocell assembly not properly
installed (not seeing the flame)
6. Dirty photocell lens
7. Bad electrical connection between
photocell and ignition
control assembly
8. Defective photocell
9. Defective ignition control
assembly
10.Line voltage is below 108V or
above 132v
REMEDY corrosponds with 1 - 10 above
1. Fill tank with kerosene
2. See Pump Pressure Adjustment,
page 10
3. See Fuel Filter, page 11
4. See Nozzle Assembly, page 12
5. Drain and flush fuel tank with
clean kerosene. See Storing,
Transporting or Shipping,
page 7
6. Check electrical connections.
See Wiring Diagrams, page 16
7. Replace ignitor, see page 11
8. Replace ignition control
assembly
9. Check for proper line voltage
1. See Pump Pressure Adjustment,
page 10
2. See Air Output, Air Intake and
Lint Filters, page 10
5. Make sure photocell boot is
properly seated in bracket
6. Clean photocell lens
7. Check electrical connections.
8. Replace photocell
9. Replace ignition control
assembly
10.Check for proper line voltage.
Disconnect power equipment
that may be used on same
line
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
When my elder tank fills up once in a while it will loose water from the tank without a flush. The water will come on for about five seconds to refill. What do you guys think the problem is?
It's the Flapper or Flush Valve. Get some green or red food coloring and a flashlight. First remove the tank lid and lift the seat and cover up against the tank. Take your flashlight and shine it on the back of the bowl, where the water line is. if you can see water coming down the back side of the bowl and disturbing the calm water ie. making ripples. ( be patient and watch carfully). If you can see the water being disturbed most likely its the Flapper. Now take your flashlight and point it down into the flush valve fill tube. That's the thing that looks like a pipe standing up in the center of the toilet tank coming out of the water about an inch or so. Look for water very slowly pouring into this tube from the inner walls.look from the top all the way to the bottom of the tube. If you see water leaking into the tube you need to replace your "Flush Valve". That's another post... If not, then most likely it's the "Flapper" put the seat back down and sit on it facing the tank. Reach into the tank and lift the flapper up and feel with your fingertip the flapper seat by circling the seat. Like you would a glass rim to make a tone with it. If you feel a nick anywhere on the seat you will need to repair the flush valve flapper seat. If not then you need a replacement flapper. If you cant see/find any of the leak problems as mentioned above then it's time to use the food coloring. Add it to the water in the tank. DO NOT FLUSH ! Let the dye mix with the water and then start to inspect the areas as mentioned above. ( Back of bowl/water line and the fill tube in center of tank). Use the flashlight to find the colored water in the areas as mentioned. Before making any repairs turn the water off to the toilet. PARTS: FLUSH VALVE REPLACEMENT If you need to replace the flapper seat flush valve. Because you found a nick in the seat rim, FLUID MASTER makes a great repair kit for that. Follow their instructions. Hint: Make sure the existing seat is dry before installing the fluidmaster repair kit. Also you get one shot at it. The adhesive is strong you wont be able to pull it back off once you install it. FLAPPER REPLACEMENT Take your old one with you to Lowes/Home Depot and match it up. Hint: Once you put the flapper on, take out most of the slack in the flapper chain when you connect it to the flush handle. once you're happy with testing the dry flush cut the remainder of the chain off with **** ( wire cutters). If the problem is a cracked overflow tube you'll need to replace the flushvalve assembly. If so you may email me at mp_collins72@yahoo.com and we'll go over that prosess on the phone if you'd like. I hope this helps. Good luck, Mike. ps. Don't forget to click on the hyperlink above for a cut away view of the toilet tank.
Dec 23, 2010 | Eljer Home
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Jun 10, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
I have an American Stadard Toilet that is only 2 years old. The toilet will not stop running. Could you give me some trouble shooting ideas?
There's a lot of variety in the works in the toilet tank. Assuming this is not a pressure-assisted toilet-----First understand the three valves are: 1. The shutoff valve - on the supply line coming into the toilet tank. 2. The fill valve - inside the tank, opens with the float descends, closes when the tank fills up. 3. The flush valve - inside the tank on the bottom. Common old style is a flapper on a pivot. Yours may operate straight up and down rather than on a pivot.
Three very common problems are---- 1. The chain that connects the handle to lift the flush valve is getting caught, not allowing the flush valve to close. 2. There is problem with the flush valve being able to get a good seal when it closes - could be debris or misalignment. 3. The fill valve is not closing when the tank is full, could need adjustment or there is debris preventing the valve to seat. . Here's are some steps to diagnose---- close the shutoff valve. Wait a few minutes as you watch the level in the tank. If the water level decreases, you have problem with the flush valve. To confirm the fill valve as the problem, turn the shutoff valve back on. Lift up on the float that is supposed to turn off the fill valve. If it shuts off, you should be able to adjust it - most have a +/- plastic adjustment screw. But if raising the float by hand only slows it down, you have problem with the seating of the fill valve - which can sometimes be cleaned, but more often would need to be replaced.
I hope this is helpful. Thanks for using FixYa.
Apr 02, 2010 | American Standard Home
The toilet is only 2 months' old. The water keeps
Remove the top of the water tank.
check to be sure that the flush cover (about in the center of the tank) can close all the way. It seats into a 2 inch hole - and must seat all the way around. If it fails to seat, then the fill valve (on the left side of the tank) will continously let water into the tank.
As a starter experiment, you may try just turning whe water off at the wall shut off. Then inspect the tank to confirm that it is losing water.
If confirmed, then the above solution is correct.
If it is not losing water, then the fill valve is faulty and will need to be replaced (it is allowing water to over flow into the "OverFlow" tube.....
I recommend that you keep the water turned off at the wall until the toilet is needed - and the problem is repaired.
Nov 15, 2009 | Kohler Santa Rosa Compact Elongated Toilet...
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
Water continues to flow after tank fills
you need to replae the float valve
go to Ace hardware and get a fluidmaster fill valve kit
they range from $7 to $9
come back
turn water off at riser( up to the tank
flush toilet remove tank top lift the flapper up and lt water drain
get bucket or small bowl
remove the plastic nut that holds the silver risr or flex line
look up under the tank there is a large lock nut screwed onto the plastic fill tank assembly
remove the nut (try to place bowl to collect wter left in tank
remove the float assembly from inside the tank
Install new fluidmaster ( flow step by step directions
good luck
Jan 05, 2009 | Home
Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
344 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
