Question about NetGear RangeMax WPN824 Router
Can receive emails but cannot send emails
I am connected wirelessly to a netgear router. I can navigate the web just fine and I can receive emails, but I am unable to send any outgoing emails. The person who lives in the house where the router is located is able to send outgoing emails so I am thinking it must either be a setting in the router or my laptop. I run windows xp.
  • 1 more comment
  • akuamoah_r Feb 23, 2009
    When I try to send a mail,I click on the new.But there be will loading on the screen while the space where am suppose to type mail doesn't appear.
  • Anonymous Mar 14, 2009
    I have the same problem
  • Anonymous Mar 18, 2014
    Works in the office on a wired network, but not at home on wireless nestork
    Problem Solver:
  • 7 Answers
If you are running Peerguardian check and see if it is blocking the domain. It does it to me sometimes. Its worth checking at least.
Posted on Feb 13, 2009
Send problems. There are several common causes of problems with sending email:
  • Mail queued. If you appear to be able to send email but it never arrives, it may be in a queue. Some applications put email in a queue when you send it, and the user has to manually send all queued mail to actually transmit it. Check your File and Edit menus for any queues, and also check the status of the email in the Out mailbox to see if it was actually sent -- if not, send it again.
  • Send on check. This is a common problem -- many email servers are configured to use the password authentication involved with checking mail to allow the sending of mail, and therefore require clients to check for mail at the same time or just before sending mail. If you get an intermittent error message and can send at some times and not others, make sure the option "send on check" is enabled in your email settings. As a temporary fix, you can often solve the problem by manually checking for mail shortly (a few seconds or minutes) before sending mail. This problem can also produce the message "relaying not allowed" described below, for much the same reason.
  • Relaying not allowed. Many Internet access providers require clients within their network to use their own servers for sending mail, as a policy intended to cut down on email spammers sending spam through other provider's servers. If you have more than one email address and can download mail without problems from a POP account with a different domain name than is used by your Internet access provider, but get the error "Relaying not allowed" when you try to send, then you probably need to set the outgoing SMTP server address to the mail server of your Internet service provider, instead of your email provider. Search your Internet network provider's home page or call technical assistance to obtain the address of their SMTP server, and enter it in your email client settings (first copy and save your existing server setting in case you need to set it back). This error message can also be produced by the "send on check" issue described in the bullet above.
  • Server down. If you can do a successful connection check, and the above suggestions don't help, and a recipient continues to say that email sent from you does not arrive, and you are certain their address is spelled correctly, then one of the email servers between you and your destination is likely down. Blocked email is typically cached and sent when the missing server comes back up, usually within a few hours or days. If the problem persists and you can successfully send to other email addresses, then the email provider of your recipient is likely having a problem -- you should contact them by phone and ask them if they are getting email from anyone else, request they send an email to you, and if necessary suggest they do a connection check from their end to help diagnose the problem.
This is from this webpage.
http://www.livinginternet.com/e/et_connect.htm
Change username
1. Open your web browser and type in your router's IP address. The default IP address for Netgear routers is http://192.168.2.1.
2. Enter your username and password once prompted by your web browser. The default username and password for Netgear routers are admin and 1234 respectively.
3. Select "Set Password" from the left hand navigation menu on the router's manager menu.
4. Type in the old password, which should be 1234 if it is set to default and then type your new password twice.
5. Click "Apply" and the new password will take effect immediately.
Nov 05, 2013 | NetGear FR114P Router
Authentication failed
A Netgear wireless router attaches multiple devices to your Internet connection, either by ethernet cable or wirelessly.
If you can't connect to the Internet, the problem can be anywhere along the chain of devices and technologies that connect your computer to the Internet.
Knowing how to troubleshoot your Netgear or other wireless router is an essential part of determining where the problem is and fixing it.
Click your "Start" button, and choose "Run."
Type "cmd" in the text box (without quotation marks), and click "OK."
A command prompt will open. Type the following: ipconfig /all. Press your "Enter" key.
A list of numbers and other networking configuration information will display.
Find your network adapter in this list of headers.
If you use your computer wirelessly in many different places, you may have to scroll through a lot of different options to find your adapter.
If you connect to the Internet using a cable, look for a header that begins with "Ethernet adapter Local Area Connection."
If you connect wirelessly, look for a header that begins with "Ethernet adapter Wireless Connection."
You will usually only see an IP address displayed under one header in either category.
Record your IP address and default gateway on a piece of paper or in a text file.
If your IP address is 0.0.0.0 or begins with 169.254, unplug your Netgear router from its power source.
Unplug your cable or DSL modem as well.
Be sure to unplug both devices; turning them off with a power switch may not have the same effect.
Wait 20 seconds before plugging the modem in again.
Wait for the lights on the modem to light up.
Plug in your Netgear wireless router again.
Wait for two minutes. Use "ipconfig /all" again.
You should have a different IP address now.
Ping your default gateway.
At the command prompt, type "ping 192.168.1.1" (substituting your default gateway address for 192.168.1.1).
You should receive four responses, all of which will begin with either "Reply from" or "Request timed out."
If you receive "Request timed out," unplug your Netgear wireless router from the power source for 20 seconds, and plug it in again.
Wait two minutes before using "ping" again.
If you receive "Reply from" responses, check to see if your Internet connection is working again.
Open a Web browser. In the address bar, type "http://192.168.1.1" (substituting your default gateway address for 192.168.1.1).
Press "Enter." If you have password-protected your Netgear router, you will be prompted for a username and password.
The default username for a Netgear router is "admin."
When you have successfully entered the username and password, your Web browser will show you the configuration page for your Netgear wireless router.
If your Web browser never loads a Web page or prompts for a username and password, you're not communicating with your Netgear router.
Double-check the address you typed into your address bar.
If you've typed it correctly and your connection is wireless, either your wireless card has a problem or your Netgear router is not correctly sending a wireless signal.
Make sure your wireless card is enabled (using Windows' built-in Network Connections applet or the third-party software that came with your wireless card).
Make sure your connection settings (SSID, security type, and key or passphrase) are correct for your network.
Look at the lights on your Netgear wireless router.
The wireless indicator light should be green.
If it's orange or not on at all, your router is not sending a wireless signal.
Make sure all the settings on your Netgear configuration page are correct.
Most Internet providers use a dynamic IP address and DNS server addresses.
Some Internet providers require a login, and some do not.
To be sure, refer to the configuration information your Internet provider gave you when your Internet access was installed, or call your Internet provider's technical support number.
Click on "Wireless Settings" on the navigation bar on the left-hand side of the page.
If you were not able to reach the configuration page wirelessly and had to connect to your Netgear router with an ethernet cable, make sure these settings are still as you defined them when setting up your network.
If not, either change the settings to suit you, or change the configuration of your wireless card to match these settings.
Be sure to click the "Apply" button if you make any changes.
Click "Router Status" on the navigation bar on the left-hand side of the page.
Under "Internet Port," check your IP address.
If the address begins with 169.254, you're not communicating with your cable or DSL modem. Unplug your cable or DSL modem from its power source for 20 seconds, and plug it back in. Wait two minutes, and refresh this page.
If your IP address still begins with 169.254, there is a problem either with the cable connecting your Netgear wireless router to your cable or DSL modem, or with the modem itself.
If your IP address is 0.0.0.0, there is a problem with your Internet connection, and you should call your Internet provider's technical support.
Record all your configuration information before trying to reset your Netgear wireless router to the factory defaults.
Resetting may fix your problem, but it will wipe out all your configuration information, and you will have to reconfigure your Netgear router from scratch afterward.
To reset most Netgear routers, use the tip of a pen or an unbent paperclip to press and hold the reset button on the back of the router until the test light blinks.
Release the button, and wait two or three minutes.
Connect to the router's configuration page in a Web browser.
Log in with the default username and password, and configure your router.
You may have to connect to the router with an ethernet cable to perform this initial configuration.
Jul 12, 2013 | NetGear Computers & Internet
N300 dgn2200 no internet connection
How to Troubleshoot a Netgear Wireless Router Print this articleA Netgear wireless router attaches multiple devices to your Internet connection, either by ethernet cable or wirelessly. If you can't connect to the Internet, the problem can be anywhere along the chain of devices and technologies that connect your computer to the Internet. Knowing how to troubleshoot your Netgear or other wireless router is an essential part of determining where the problem is and fixing it.
Instructions
1Click your "Start" button, and choose "Run." Type "cmd" in the text box (without quotation marks), and click "OK." A command prompt will open. Type the following: ipconfig /all. Press your "Enter" key. A list of numbers and other networking configuration information will display.
Find your network adapter in this list of headers. If you use your computer wirelessly in many different places, you may have to scroll through a lot of different options to find your adapter. If you connect to the Internet using a cable, look for a header that begins with "Ethernet adapter Local Area Connection." If you connect wirelessly, look for a header that begins with "Ethernet adapter Wireless Connection." You will usually only see an IP address displayed under one header in either category.
3Record your IP address and default gateway on a piece of paper or in a text file. If your IP address is 0.0.0.0 or begins with 169.254, unplug your Netgear router from its power source. Unplug your cable or DSL modem as well. Be sure to unplug both devices; turning them off with a power switch may not have the same effect. Wait 20 seconds before plugging the modem in again. Wait for the lights on the modem to light up. Plug in your Netgear wireless router again. Wait for two minutes. Use "ipconfig /all" again. You should have a different IP address now.
4Ping your default gateway. At the command prompt, type "ping 192.168.1.1" (substituting your default gateway address for 192.168.1.1). You should receive four responses, all of which will begin with either "Reply from" or "Request timed out." If you receive "Request timed out," unplug your Netgear wireless router from the power source for 20 seconds, and plug it in again. Wait two minutes before using "ping" again. If you receive "Reply from" responses, check to see if your Internet connection is working again.
5Open a Web browser. In the address bar, type "http://192.168.1.1" (substituting your default gateway address for 192.168.1.1). Press "Enter." If you have password-protected your Netgear router, you will be prompted for a username and password. The default username for a Netgear router is "admin." When you have successfully entered the username and password, your Web browser will show you the configuration page for your Netgear wireless router.If your Web browser never loads a Web page or prompts for a username and password, you're not communicating with your Netgear router. Double-check the address you typed into your address bar. If you've typed it correctly and your connection is wireless, either your wireless card has a problem or your Netgear router is not correctly sending a wireless signal. Make sure your wireless card is enabled (using Windows' built-in Network Connections applet or the third-party software that came with your wireless card). Make sure your connection settings (SSID, security type, and key or passphrase) are correct for your network. Look at the lights on your Netgear wireless router. The wireless indicator light should be green. If it's orange or not on at all, your router is not sending a wireless signal.
6
Make sure all the settings on your Netgear configuration page are correct. Most Internet providers use a dynamic IP address and DNS server addresses. Some Internet providers require a login, and some do not. To be sure, refer to the configuration information your Internet provider gave you when your Internet access was installed, or call your Internet provider's technical support number.
7Click on "Wireless Settings" on the navigation bar on the left-hand side of the page. If you were not able to reach the configuration page wirelessly and had to connect to your Netgear router with an ethernet cable, make sure these settings are still as you defined them when setting up your network. If not, either change the settings to suit you, or change the configuration of your wireless card to match these settings. Be sure to click the "Apply" button if you make any changes.
8Click "Router Status" on the navigation bar on the left-hand side of the page. Under "Internet Port," check your IP address. If the address begins with 169.254, you're not communicating with your cable or DSL modem. Unplug your cable or DSL modem from its power source for 20 seconds, and plug it back in. Wait two minutes, and refresh this page.If your IP address still begins with 169.254, there is a problem either with the cable connecting your Netgear wireless router to your cable or DSL modem, or with the modem itself. If your IP address is 0.0.0.0, there is a problem with your Internet connection, and you should call your Internet provider's technical support.
9Record all your configuration information before trying to reset your Netgear wireless router to the factory defaults. Resetting may fix your problem, but it will wipe out all your configuration information, and you will have to reconfigure your Netgear router from scratch afterward. To reset most Netgear routers, use the tip of a pen or an unbent paperclip to press and hold the reset button on the back of the router until the test light blinks. Release the button, and wait two or three minutes. Connect to the router's configuration page in a Web browser. Log in with the default username and password, and configure your router. You may have to connect to the router with an ethernet cable to perform this initial configuration.
Tips & Warnings
You can use the "ipconfig /all" command on almost any computer that connects to a network or the Internet. If "cmd" doesn't open a command prompt, you can use any method your operating system allows to open the prompt or shell. If your Netgear wireless router is not sending a wireless signal even after you've powered it off, waited 20 seconds and powered it back on, you can use an ethernet cable to attach a computer directly to the router to continue troubleshooting.
Jan 07, 2012 | NetGear Computers & Internet
How to configure my router with laptop?
  • 1.Launch your Web browser and then type 192.168.1.1 in the address field. Click "Enter."
  • 2.Click "Basic Settings." Input the configuration information given to you from your ISP in this screen. The settings not given by your ISP can likely be left at their default value. Click "Apply" before navigating away from this screen.
  • 3.Click "Wireless Settings" in the menu on the left side of the screen. Enter or select the appropriate settings in the Wireless Settings dialog. Select the appropriate Security Options, then generate the security key. Click "Apply" before navigating away from the Wireless Settings dialog.
  • 4.Reboot the router for the changes to take effect.
  • Good Luck, Jopica123
    May 17, 2011 | NetGear WGR614 Wireless Router
    I have a WNDR3700 V2 - Internet & wireless working fine. Email not working. Any ideas
    If your internet connection is okay and you connect to your email is thru your web browser, (http:// or https://), the problem isn't with your router. Its most likely either a problem with the email service or you have a virus.
    What email service are you using and what is the exact problem (can't login? can't access the website???)
    Feb 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
    Cant send emails on Netgear MBR624GU
    it could be your email provider lagging and having technical issues. or maybe even doing system repairs and you just happen to be checking your email as the process was taking place.
    Apr 14, 2010 | NetGear MBR624GU Wireless Router
    Have vonage fax and phone service
    I am new in the network field.How can i set up a LAN net work using 5 hosts.What are the devices that I need to set up this net work?This is my email address.You can send it there:tunjiman23@yahoo.com.Mnay thanks
    Apr 02, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
    Installed Netgear but can't send e-mail
    Ya have to "Open a Port" or "Port Foward" to allow your SMTP and POP3 services to communicate with the Server.. so find out what "Ports" ya need open and using the Admin interface change them to allow your emails to work. This info is generally found in the Manual of the router or online.. And OR your firewall hust be set to pass them on thru too..
    Jun 13, 2007 | NetGear WGT624 Wireless Router
    NetGear RangeMax WPN824 Router Logo
    969 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
