Question about Irons
Light comes on, but iron will not heat up
The iron is plugged in correctly. The light come on, however the stainless steel bottom remains cold no matter how long the iron plugged in to the power outlet. The power outlet is working ok, as I am using it to charge my phone, vac, etc. Please advise what can be done to correct the problem. plugged in lights up but not heat up product: tefal aquaspeed 150
  • Anonymous Feb 22, 2009
    I have exactly the same problem with my Tefal Virtuose FV9140 iron- light comes on but doesn't heat up. Would appreciate any ideas.
  • robbimac Feb 23, 2009
    My Oliso TG-800 iron has power for retractable feet, but does not heat at all. Iron is over 1 year old and worked perfectly until this problem.
Oliso iron turns on when plugged in green light flashes but iron will not heat up
Posted on Apr 11, 2009
Rowenta i ron stopped working
If you didn't keep it clean, it may have just burned out. Hard to say.
Dec 31, 2017 | Rowenta Irons
How do I use the self clean button in the DW5080 Focus 1700 Watt Steam Iron
please read carefully the owner manual and get the information about how to use the steam.
download from www. fitness.manualsonline.com
God bless you
Feb 01, 2013 | Rowenta DW5080 Focus 1700 Watt Steam Iron...
Iron won't come on or heat
Hi
The problem could be the power cord or the element.
Try replacing the power cord first and see what happens.
Feb 28, 2012 | Irons
My Rowenta iron was working fine the last time I used it. I plugged it in to use it today and nothing. The little red light on top comes on but the light on the side to let me know it is ready and hot...
Yes there is a solution, I have a DG580 with the same problem. I had to replace the electric cord which cost $17.00 and took 30 min to replace and now works like brand new.
Steve
Dec 02, 2010 | Rowenta Irons
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
My Rowenta iron seems to be scortching my white clothes, the plate is stainless steel but seems to look iridescent
if its a light brown appering on the whites, its just to hot, lower setting. also make sure the plate is clean. the stainless changes colour from heat after a while, this is normal
Aug 08, 2009 | Rowenta Professional DM890 Iron with Auto...
Rowenta Iron
TO CLEAN THE BOTTOM OF THE IRON, MY NAN USED TO ALWAYS IRON BROWN PAPER, IF THIS DOES NOT WORK, USE A RAG DIPPED IN THINNERS, OR LIGHTER PETROL AND RUB GENTLY.
NORMALLY THE SELF CLEAN SYSTEM IS JUST A BUTTON NEAR OR ON THE TANK THAT YOU PRESS WHILE THE IRON IS ON AND HAS WATER IN, PRESSING THE BUTTON WILL FORCE WATER THROUGH THE STEAM JETS (SO KEEP IRON FACING DOWN) ALSO EMPTY THE IRON AFTER EVERY USE
Nov 27, 2007 | Rowenta DE-480 Iron
Like what was posted before, the cause of the iron lights is on but the heaters are not hot is because either your heater connection is melted or rusted due to water seepage(steam irons). The lights power supply are tapped parallel to the heater supply thus lights is on. Solution is to dismantle the iron to replace the connectors or cables. Though not all iron is easy to dismantle
Nov 13, 2007 | Irons
I have the same problem with my black and decker iron. I will not buy orrecommend this iron to anyone.
Aug 09, 2007 | Sunbeam Safety Glide 3891 Iron
Irons Logo
1,323 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
