Question about Maytag MMV4205 Microwave Oven
Microwave MMV4205aa no power, circuit is fine. contol panel is blank. feset orfuse?
  • 1 more comment
  • Anonymous Mar 24, 2009
    I have the same problem. We have looked at the fuse and tested it and it tests out okay.
  • Anonymous Apr 25, 2009
    No power, nothing, both 250v 20 amp fuses are good. This is the second time this has happened. It was fixed the first time under warranty. The repair man took it down, removed a panel, did something (unfortunately no one was watching closely), and it worked until is just failed again with the same symptoms (no lights, no clock, nothing), three days after the 1 year warranty expired.
  • Mark Egan May 11, 2010
    There is an internal fuse that may have blown.
    Replace only with same type and amperage, and be prepared that it may blow again due to a more serious problem.
  • Maytag Master
  • 9,098 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can probably download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
Your problem is likely a blown fuse, a bad magnetron thermal cutout / thermostat, or a bad oven cavity thermostat.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool / Amana owner's manuals and installation instructions here.
Posted on Feb 15, 2009
Maytag model mmv4205aa have electric no power in micrcrowave
This previous answer should help you.
Aug 31, 2012 | Maytag Appliances Over-the-Range Microwave...
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
Need to replace the door on MMV4205AA
You can find handy exploded views and order parts by model number here.
May 31, 2012 | Maytag MMV4205 Microwave Oven
Went to warm up a food item and after 3 seconds the microwave shut off like the circuit breaker tripped. time face went blank, light inside does not light up and stove top lights do not light. circuit...
You have a fuse behind the screen panel. You have screws inside the microwave holding the panel. you have 1-2 at the bottom. You may also have to remove the vent. It has 2-3 screws which will be inside the vent. These can be removed from the front. Once these are removed the panel will pop off and you will see the fuse The fuse can be bought at a radio shack. BE SURE TO UNPLUG THE MICROWAVE! Good Luck
Dec 04, 2010 | GE JVM1631 Microwave Oven
Fan and light keep running and panel is blank
mcdevito75 here, Sounds as though the control board could be faulty, check with any appliance repair center in your area.
Jul 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MMV4205AA Microwave will not turn off
Check for damaged, contaminated door switches/clips.
Dec 17, 2017 | Maytag MMV4205 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
269 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
