Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
The usb storage device don't work and don't appear in my computer what can I do for this please help me
  • Anonymous Mar 23, 2009
    Jag sitter också med samma problem. Tror att det uppstod efter XP sp3. Usb fungerar för övriga enheter men inte masslagringsenheter, Mp3, Usbminne etc. Däremot fungerar tangentbord, mus, webkamera osv. Sätter du i ett usbminne så får du utropstecken i kontrollpanelen men datorn hittar inga drivrutiner trots att det fungerat tidigare. Det hjälper alltså inte med ASUS senaste för moderkortet. Det fanns någon fix för registret som handlar om USB men det löser heller inga problem.
    Börjar bli frusterande måste jag säga. Man kan ju byta moderkort med det känns lite onödigt för något som det borde finnas en lösning på. Får väl kontakta Asus för att be dem ta fram nya drivar.
First thing to do would be to check to ensure that your usb device isn't trying to assume the same drive letter as a mapped drive on your system. to check this, right click my computer icon, select manage, double click storage in the right pane, double click disk management snap in. You should see all storage devices connected to your pc. Mapped drives won't show up in there, so if you see a storage device with the same drive letter as a mapped drive change it to something else by right clicking that device, select change drive letter and path, and execute.
If it doesn't show up in your storage list, right click the my computer icon, select properties, click the hardware tab, select device manager, and at the top of device manager you should see an icon that looks like a pc with a magnifier over it, click that and it will search for new hardware and changes.
also, you may want to try moving the usb to another port on your computer, (ex. if you have it plugged into the front, try plugging into the back)
Posted on Feb 13, 2009
3 Suggested Answers
  • 42 Answers
SOURCE: system shutdown in 15 seconds
hi, pl check for viruses, scan the system, and go to cmd prompt and issue this commnd at c:\ shudown -a and press enter to disable reboot and scan the system and check any hardware issue.
Posted on Aug 12, 2008
  • 508 Answers
SOURCE: System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
Posted on May 31, 2010
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
I don't see photos on BenQ DC C1030 Eco
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 02, 2012 | BenQ DC C1030 Eco Digital Camera
The play back button of my nikon coolpix s200 is not working. i don't know how to fix it. please help me... i cannot view my previous pictures..
Sep 12, 2012 | Nikon COOLPIX S200 Digital Camera
I need driver called mtp usb device for my c2-03 mobile
Many devices use Microsoft's Media Transfer Protocol to synchronize with computers. Unlike standard USB mass storage devices, MTP devices don't behave like USB flash drives. Windows Media Player includes built-in support for MTP devices and can synchronize media files to and from them. You can download MP3s to your portable music player, cellphone or other MTP device using Windows Media Player's sync feature. The device appears in Windows Media Player when you connect it to your computer.
Read more: How to Download a MP3 to MTP ' eHow.com http://www.ehow.com/how_12186594_download-mp3-mtp.html#ixzz1wFmzrcvt
May 29, 2012 | Nokia C203
One day, I uninstalled USB Mass Storage Device along with a bunch of other ones (eg. USB Root Hub & some other ones) The USB Root Hubs and the other ones re-installed but the USB Mass Storage Device...
The hubs were most likely the USB hardware that is a part of your computer, but the USB Mass Storage Device is a part of some hardware that you had plugged in at some point (maybe a USB flash drive, maybe a USB external drive). In order to reinstall the Mass Storage Device, you have to plug that hardware back in and let it reinstall. If you aren't aware already, sometimes you plug in one device, but it installs as more than one device (it's actually supposed to). So you won't always have a one-to-one ration of hardware and installed devices, since some of them show up as more than one device. And typically, when plug a new device in for the first time, the computer can only see one device, then it instals that one device, and only then can it see the other (virtual) devices, which it then installs. The next time you plug that device in, it sees & activates all of the devices instantly & silently (not counting the little "plug in" sound it makes).
Aug 08, 2011 | Microsoft Windows XP Professional Full...
How to turn on mass storage mode in sony x8
Hi Sweet Chris,
You don't have to select mass storage in Android phones just follow the following instructions:
1 Connect your phone to a computer using a USB cable.
2 Phone: Tap Connect your phone. The memory card is mounted to the computer.
3 Computer: Wait until the phone memory and the memory card appear as external
disks in the file explorer(My Computer).
4 Computer: Drag and drop or copy paste selected files between the phone and the computer.
If you find this solution helpful please give feedback.
Regards,
Sandy
Jul 07, 2011 | Cell Phones
How do i get photos on to my garmin
Connect gps to computer with usb lead.
drag and drop photos from computer to GPS (which will appear as a mass storage device).
Please dont forget to vote this answer was helpful
Many thanks
Feb 16, 2011 | Garmin Nuvi 265W GPS Receiver
Bios setup error
check your c-mose battery when power cable is unplugged the battery remove and after few seconds battery fix them and connect power cable then on the computer
Oct 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Problem installing driver
I first found that when I plugged my player into my computer it registered it as a MTP (Media Transfer Protocol) device and in turn never showed up as a storage device on my computer. I fixed this by going into my Control Panel -> System Icon -> Hardware Tab -> Device Manager button. Clicking on the “System Devices” tab should have “Walkman” or MTP device. Right click on it and go to properties, now before doing anything it should say “Location — —— Location 0 (Walkman)” if not try unplugging the walkman and see if the MTP device you’re looking at is removed from the list, just to make sure it’s the right device we’re looking for.
If you’ve confirmed it’s the Walkman, click on the “Driver tab” and click on “Update Driver…”. Then click on the “Install from a list or a specific location (Advanced)” option and click “Next”. Now select the “Don’t search. I will choose the driver to install.” and click next. It should now bring up 2 driver choices, one being “MTP Device” and the other “USB Mass Storage Device”. Select the USB option and select next, it will then install your walkman as a USB storage device and after that’s done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in “My Computer”"
Jul 06, 2008 | Sony Walkman NWZ-S616F MP3 Player
Usb cruzer micro and other usb storage devices malfunction and not recognized by the computer.They all work well with other computers - I've tried already to update every driver and firmware but with no...
Could you give me information on the computer your using? I'd need the mother board manufacturer, the bios manufacturer, the bios revision number, The operating system your using, The revision number of your operating system, And is it only usb storage media that your having trouble with, or does your issues include usb imaging devices?
Nov 30, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
142 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
