Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP, color wheel
Samsung DLP Tv. Replaced color wheel now I have smurfs on the screen the color is bad. Now I'm hearing that I may have the wrong wheel or I have to make an adjustment. Help please.
  • 4 more comments
  • mkandersongc Feb 13, 2009
    Did that. HLP 5663W, part # for color wheel BP96-00674A
    Coloe replaced, Color horrible, HLP5663W color wheel part # BP96-00674A. , I'm confident installation went fine.
    What are these setting. Could it be like 102327104
    Help
    What would the color wheel setting be
    I can't see how to reset color. Got to Service menu it has a lot of different colors and settings. How to reset, and shouldn't the color wheel already be set up.
    Genius:
  • 1,913 Answers
U have to check dispaly resolution and colors settigns.
1 st set all settigns to factory defaults.
Posted on Feb 13, 2009
    Scholar:
  • 75 Answers
    President:
  • 1,902 Answers
According to my HLR service manual, after replacing the color wheel you need to go into the service menu and adjust the Index Delay and CCA. The adjustments are 6 and 7 step procedures, each (but they look easy in the manual). You can get a service manual for your tv at samsungparts.com and do the procedures if you are comfortable with the service menu.
  • 15,935 Answers
This is a known issue you received a newer colorwheel on the board where the color wheel plugs in you will find a jumper you need to move the jumper to the other colorwheel setting because on the new color wheel it inverter the two colors it helps because the new wheels have better pic quality. (they say)
Move the jumper and this will resolve the polarizing but since you already adjusted the cca you now will need to adjust it one more time to finish the alignment.
Hope this helps
  • blueextc3221
    blueextc3221 Feb 13, 2009
    There is a small slip of paper that was supplied with the color wheel. This has specific parameters for the color wheel you installed.
    In order to set the values, you will need a service manual. Also their is a jumper on the light engine that may need to be removed.
    If you are not familiar with these procedures, I recommend you contact a service company and have them do it for you.
    If you have misplaced the parameter sheet, the setup will be more dificult.
  • 142 Answers
You could have the wrong color wheel. Before you research that though, I am sending you directions on how to correctly install the one you have. They are long so I am going to send a link.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Retrace your steps and try again. I know this will help it is a simple repair.
Please remember to rate this answer.
    Sergeant:
  • 250 Answers
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Most times color does not gets reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has been replaced with a new airless bering color wheel.
this is to reset lamp hours still try that if that is the problem this instructions will help you. The service menu is pretty well hidden behind a sequence of key presses on your remote. Here’s how to get in there:
1. Turn your system off.
2. Press the following buttons individually with a short pause between each: Mute-1-8-2-Power.
The Television will turn on into the service menu. Once in there look in the Options menu for the lamp hours and counter reset. As for the other settings, I’ve never messed with them, and I’d caution against playing around there!
    Sergeant:
  • 326 Answers
How to replace the colour wheel with diagram and procedure
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
check out this links for all the settings you need.
please do rtate the solution.
thanks.
    President:
  • 2,110 Answers
Remove the small black pin jumper in the back center of dvm modual.
it looks like a larger hard drive jumper.
ther is a squair hole cut in the tin bach mesh
use tweesers to remove the black jumper.
The jumper is on the dmd bd. close to the dlp chip heat sink. Need tweesers or small needle nose to slide the jumper off of the two small pins. Each BP96-00674A color wheel has the new CCA settings taped to the new wheel. You must enter the the service menu and reset the CCA's for this color wheel.
to get to the service menu start with the tv off and then press mute > 1 > 8 > 2 > power on the remote the tv will come on with the menu displayed
  • 163 Answers
Hi!! you have a bad color board device..Call 1-800-samsung for some other issue on this.Goos luck..
  • Samsung Master
  • 19,396 Answers
You need to replace the color wheel , let me know the exact model, so that I can find a replacement.
Is it possible to have only the red tint projector lamp replaced on 61" projector Samsung tv
No. This is a DLP TV. It gets it's color by a color wheel. If color seems to drift across screen or there is a loud-ish whining noise from back of TV that you can here clear across a room, then this color wheel may be bad. They wear out.
Jan 07, 2015 | Samsung HLN617W 61" Rear Projection HDTV
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
I have a rubbling noise when the TV is on. The picutre and the the souind is clear although you hear this loud rubbling (bad bearing noise) fromtheback of the TV. When you turn the TV of, the noise is...
This DLP tv have a colors wheel.No,the colors wheel is dying,just not dead yet.It spinning off of it motor axis,when it total dead it will have black&white pics,very loud squiling motor noises.Ur tv need a new colors wheel.Call the tv repair tech for this job,require take out many machanicals parts,before even can take the colors wheel to replaced.Never done this before,don't atemp to replaced the colors wheels ur self.
Jun 14, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
Black screen with sound. we replaced the lamp but screen is still black.
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. Also make sure everything is properly closed (door cover) if it's not properly shut it won't be able to light the lamp.Have a bless one!
Mar 31, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
Rattling sound from the Samsung DLP TV
Your Color Wheel is bad and needs to be replaced by a trained Samsung tech. There are adjustments that must be made after the color wheel is replaced. Part# is BP96-01579A
Jul 15, 2009 | Samsung HL-S5087W DLP TV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
858 people viewed this question
Jerry Greenberg
Jerry Greenberg
