Question about Bosch WFMC 3200 Front Load Washer
Wfmc 3200 fixed E04 problem, where does the gasket go?
I took off the black cap in the front, removed a sock, and the E04 problem was fixed. However, a black rubber gasket (about 1 1/2" in diameter) came off in the process & not really sure exactly where/ how it goes.
Also, despite having tightened the black cap & put it on properly with the bottom indicator in the right place, the machine leaks a lot from the cap during drainage.
    President:
  • 1,902 Answers
Take the cap back off. Put some pipe thread sealent on it. Just some basic pipe thread tape should do the job.
Posted on Feb 13, 2009
Can't get retaining rings back on boot gasket on Bosch 3200uc
You can google for them or look on this site Fixya for spares.
Mar 19, 2013 | Bosch WFMC 3200 Front Load Washer
BOSCH WFMC3200 Washer - Receiving E04 error and manual indicates clearing drain hose and pipe. How do I remove the cover on lower front of machine?
there is small hole in the cover you need to push a small screwdriver or ice pick works in the hole and then turn clockwise till it comes off.
But there will be some water come out so if you have a wet dry shop vac then use it on the end of the drain hose to remove most of the water then keep it handy when you take the plug out there will still be some water come out and you should be able to clena out the trap area
Nov 30, 2010 | Bosch WFMC 3200 Front Load Washer
Installation of bello gaskit
Did you remove the complete front panel to remove gasket? If not, you are going to struggle to get new one on and refit the inner spring. Usually if you add a few drops of washing up liquid to the inner crease of the door gasket it will help.
Jul 11, 2010 | Bosch WFMC 3200 Front Load Washer
MACHINE NOT DRAINING ERROR CODE E:04
check the hose it's clogged or the stainer it's clogged too
Jan 15, 2010 | Bosch WFMC 3200 Front Load Washer
We are getting error message E04 on our Bosch front loading machine and it won't drain and it makes a grinding sound.
We removed the round panel in the front and there was a knee hi stocking stuck in the filter - great advice - it's fixed and working perfectly.
Jan 03, 2010 | Bosch WFMC 2100 Front Load Washer
Need the process to remove pump from bosch wfmc 3200 washer?
Do a Internet search and type in the model and diagram.
Nov 19, 2009 | Bosch WFMC 3200 Front Load Washer
Put front gasket back on
start on the door side of the appliance put the top of the circle in first this should allow you to stretch the spring a little to make it go on
its a pain and it kills the tips of your fingers try not to overstrech it because it will fall off all the time
Mar 12, 2009 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Dec 18, 2008 | Bosch WFMC 3200 Front Load Washer
Rubber gasket Bello!
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
Apr 29, 2008 | Bosch WFMC 3200 Front Load Washer
Water not entirerly draining, e04 code continues on...
you did not say what make ,but anyway,there is probably a obsuction in the bottom hose on drum, ie sock, underware remove it and see.. close ire
Nov 27, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
149 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
