Question about Canon Office Equipment & Supplies
I am getting errormessage as E 005 How can solve this problem in IR 400
  • 1,031 Answers
"Switch Main Switch off and on after some time".if the problem still remains then It involves getting the fuser out of the machine
The fuser comes out relatively easy from the left access door. undo the metal straps holding it. Make sure the machine is unplugged, remove the connectors on the left of the fuser, as well as the exit sensor connector on the right. The green fuser knob inside the front cover has to come off too.The web needs to be replaced and counter cleared in service mode.
The web assy comes off with two screws. Make note of how it's wound, you'll want to make sure you put the new one on the same way.
Put it all back together. When you turn the machine on for the first time, you'll still get an E005, at this point, hit *,2 and 8 together,* to get into service mode. Under the heading "counter" then "misc" you'll find the web counter. Highlight it and hit clear. Turn the machine off and on, .
The odd time I've still had it give me a code, if this happens, get into service mode, "function" tab, "clear" then "error". Power off and on.
Posted on Feb 13, 2009
  • Starnley Johnwells
    Starnley Johnwells Feb 13, 2009
    hope this helps pls do let me know if you need further assistance ill appreciate a fixya rating .thanks and Godbless
Sir,
I am getting an error E803 in Ir 400 .
How can i solve this problem
Posted on Apr 23, 2010
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
DEAR SIR, MY CANON IR 400 MACHINES COPY IS TOTALLY BLACK .I WILL NOT HAVE ANY TYPE OF KNOWLEDGE . PLEASE GIVE THE ANY RESOLUTION, FOR GET CLEAR COPY OR ANY TYPE OF FUNCTION IS USE FOR CLEARING...
I will tell you the problem but you need Technician. First try cleaning/replace the flash rom or change tthe Camera together with the CCD Board.
May 11, 2011 | Canon imageRUNNER 400S Copier
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Mar 02, 2010 | Office Equipment & Supplies
Form creat in flash
  1. Create a new document and set the size to 400 x 300 ("Frame" > "Frame Size")
  2. Set "Frame 1" to "Stop" ("Frame" > "Frame Delay" and check "Stop", click OK)
  3. Draw 2 edit fields with the "Edit field" tool, they will appear as Edit1 and Edit2. Double click each field and make sure HTML is not checked, uncheck if necessary.
  4. Draw a button, double-click it and rename it to "OK".
  5. Draw edit field labels "Phone" and "Email" with the text tool. Double click each field and make sure HTML is not checked, uncheck if necessary.
  6. Draw "ErrorMessage" field with the "Text Paragraph" tool. Choose "Item" > "Text Color" and change it to red. Choose "Item" > "Placement Properties" and rename the field to "ErrorMessage"
    1. Select the button, choose "Item" > "Actions" > "OnClick". Select "ActionScript" and paste the following code:
    // reset error message
    ErrorMessage = "";
    // validate phone field
    phone = Edit1;
    if(phone=="") ErrorMessage = "Enter your phone";
    // validate email field
    email = Edit2;
    if(email=="") ErrorMessage = "Enter your email";
    if(email.indexOf("@",0)<0) ErrorMessage = "Enter valid email";
    if(email.indexOf(".",0)<0) ErrorMessage = "Enter valid email";
    // build message string
    message = "mailto:support@selteco.com?subject=Title&body=Form contents%0A";
    message = message + "phone: " + phone + "%0A";
    message = message + "email: " + email;
    // execute form if errormessage is empty
    if(ErrorMessage=="") getURL(message,"_self");
Hit F9 to preview. The form will not work until you export Flash file and HTML page. Choose "File" > "Export HTML Page" to create HTML page and test the form in a browser. This form is using very basic validation. Use "%0A" as line separator.
Use the following functions or attributes of the string:
  • length returns the number of characters
  • charAt(x) returns zero-based character at position x
  • indexOf(substring,startindex) returns the position of the first occurrence of the specified substring or -1.
  • lastIndexOf(substring,startindex) returns the position of the last occurrence of the specified substring or -1.
  • substr(start,n) returns n characters string starting at specified position
  • toLowerCase(), toUpperCase() converts the string to lower or upper case
Jan 21, 2009 | Computers & Internet
Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Mar 15, 2008 | Canon imageRUNNER 400S Copier
Service manual
I want user manual for cannon imagerunner 400 / 330 series
Sep 19, 2007 | Canon imageRUNNER 400S Copier
164 people viewed this question
old marine
old marine
