Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Light Problems on garage Door Opener
The light stays on when the garage door remains open for over 5 minutes. If the door is opened and closed for short periods of time, the light goes out like it is supposed to do.
    Problem Solver:
  • 8 Answers
Its possible there could be a problem with the circuit board, the other possibility is that every time you break the beam of the photo-eyes located at the bottom of the tracks, the lights come on for another 4.5 minutes (if it is a chamberlin brand opener).
Posted on Feb 27, 2009
My Liftmaster garage door light sometimes stays on all night after operating the door. If I turn off the circuit breaker for an hour or two, then the garage door opener light stays on for the normal 2...
I would just have someone come and check it out to see if it is the light or the electrical. Hopefully it is only a matter of cleaning it off and and replacing a piece or two. Good luck with the repairs and hopefully it is nothing to serious.
Jason http://goodrowdoorsolutions.com/products-and-services.html
Mar 02, 2013 | Sears Craftsman LiftMaster Chamberlain...
The light on my craftsmans model 139.53990 garage door opener comes on when the door is opened but only stays on about 5 seconds. It lights when closed and stays on the normal length of time.
Very strange but you can try this. Unplug the opener and remove the light bulb. Use a small screwdriver and pry out on the center contact in the light socket. Replace the bulb and plug the opener in.
Aug 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Overhead light stays on all the time on craftsman garage door opener
Hello. If the light stays on all the time check these:
A. The light time delay on the opener will keep the light on for approximately 4-1/2 minutes after the system has be activated, then will turn the light off automatically.
B. If the opener has a worklight switch (which is supplied only with a four-function wall console), slide the switch to "OFF" position.
C. If the opener has a pedestrian switch (which is supplied only with a four-function wall console), the light will stay on for 4-1/2 minutes after the pedestrian door has been opened.
Mar 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
The light on my garage door opener will not go out. It should go on and off automatically with each opening or closing. I had to unscrew the bulb, because I knew it would burn out anyway with continuous...
MANY NEWER DOOR OPENERS ACTIVATE THE LIGHT EACH TIME YOU BREAK THE SAFETY SENSOR BEAM.
THE LIGHT SHOULD STAY ON FOR ABOUT 4.5 MINUTES EACH TIME THE OPENER MOVES OR THE BEAM IS BROKEN.
DOES YOU WALL CONTROL HAVE A LIGHT BUTTON??
IF NOT THE CIRCUIT BOARD STILL HAS THE ABILITY TO WORK WITH ONE THAT DOES. I HAVE SEEN SOME WHERE THE ONLY WAY TO TURN OFF THE LIGHT WAS TO CONNECT A 3 BUTTON WALL STATION & TURN OFF THE LIGHT - THEN RECONNECT THE PUSH BUTTON - OR YOU COULD LEAVE THE 3 BUTTON WALL CONTROL.
YOU MAY ALSO TRY UNPLUGGING THE UNIT FOR ABOUT 5 MIN. THIS RESETS MANY OF THE CIRCUITS ON THE BOARD.
HOPE THIS HELPS
Apr 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage light turns on without disturbance.
Most likely the unit has a sensor that activates the light when you walk around or open the door.
if no one is in the room it should go off in 5 minutes, but if someone goes back in there to check it goes back on again.
Under the light cover there should be a switch where you can disable it or make it less sensitive.
Sep 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
547 people viewed this question
Top Chamberlain Car Audio & Video Experts
Iron
Iron
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
