Question about GE WBSR3140DW Top Load Washer
Just out of storage, my washer is having difficulties.
When first hooked up after long storage, it would not spin, my son gave the drum a few helping turns and that seemed to do the trick. next two wash cycles went fine but that was it, then it wouldnt agitate, I gave it a helping hand and it agitated for the wash but then wouldnt spin and in rinse cycle it wouldnt agitate or spin. Now it will only run water in and out. It doesnt make any strange noises and there are no smells or leaks. In the agitate part of wash the drum seems to be locked but in spin you are able to turn drum but not easily.
  • 256 Answers
Hi, There are capacitors that give an initial boost to start the motor moving and these tend to go bad from sitting for long periods, that's why you could give it an assist and it would work, you are providing the extra boost. Helping it though causes other problems, like belt and voltage control problems, so that is not a good idea. You should have it looked at if you are not electrically or mechanically inclined. Best of luck to you!
Posted on Feb 13, 2009
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but...
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
May 08, 2011 | Kenmore 22422 Top Load Washer
Have a Whirlpool Super Capacity washer in which the drum will tilt during the wash cycle and spill water. If held to center, there is no leak, and the cycle completes without difficulty.
Could you tell me what the life expectancy for this washer might be and does it have a good track record. (Mom gave me one) Whirlpool Super Capacity Plus 7-Cycle 2-speed. 3.2 cu. ft
Mar 02, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
I have a whirlpool washer lxr7144e01 the water drains out but it wont spin. It looks like the drum is not sitting level anymore. You can hear something runing under the drum.
the drum support spring/s have come off,,letting the drum drop a few inches,,take the top or back off and the support springs can be put back on or new ones fitted,,the springs fit into the top of the washer case and hook onto the drum
Jun 28, 2010 | Washing Machines
My washer tends to have difficulty spinning if the load is too heavy and it is really loud when it does decide it will work. It works well with smaller loads but when i try to wash more than just a few...
Your load drum bearings appear to be in the process of seizing, thus putting excessive load on the drive motor and this causes it to trip its self out
Jun 24, 2010 | GE Profile Prodigy WPSE4200A
LG front loading washer: recently moved to a new house and laundry room is on the 2nd floor. Re-installed the shipping bolts in the back of the washer that secures the drum prior to moving the washer. But...
Make sure machine is level and all four leveling legs are solidly touching floor at the same time. Make sure leveling leg locking nuts are screwed up to lock legs in place. Check floor for firmness. (try bouncing up and down in front of washer to see if the floor has excessive give.) You may need to re-inforce floor. Wash larger loads. On bulky items, use a lower spin speed. You can re-spin at a higher speed after cycle is complete if you want them spun out better. (some models have a pump and spin only setting, on others, just turn on the power and then only touch the spin speed button to select a 14 minute pump and spin only cycle, then touch the start button.) The only other thing is that the new LG washers use a balance ring now, which makes the machine perform much smoother. (I know because I gave my old LG to my son and replaced it with the newer model, which now runs much quieter, in the exact same location as the old one.)
Jan 13, 2010 | Washing Machines
My clothes will not spin to wring out the water
Clutch is bad, Control Panel Bad, or Motor Control Board bad. Usually the clutch you can get a new clutch online fron an appliance parts dealer there are several so shop around. INSIDE THE BACK COVER IS THE OWNERS MANUAL remove a few screws and get it. This will help aid you in self repair of MAYTAG :( I finally gave up and bought an old standard machine and I have no worries or problems with my washing machine, no stinky drum or clothes, no break downs, and no half washes. I ll never buy another high end washer set again, never.
Oct 13, 2009 | Washing Machines
My megawdss will not spin everytime can you help
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Sep 27, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic washer draining but not spinning
Sep 05, 2009 | Baumatic MEGAWDSS Front Load Washer /...
GE WBSR3140DW Top Load Washer Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
