Question about Bush WS6671 28" TV
Cant turn tv on when red light is flashing
Bush lcd 27 inch tv is stuch on flashing red can some one help thanks
  • Bush Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
The power for my bush tv model number led26982hdt
My bush television wont turn on from standby? - Ask Me Fast
www.askmefast.com > Consumer Electronics > PlayStation > Wont
Hi my bush tele wont turn on it just keeps flashing at me standby light i ve changed the fuse .... Bush 22 inch tv dvd combi keeps restarting remote doesnt work.
22" bush tv wont turn on - The Student Room
www.thestudentroom.co.uk > ... > Sound and vision
The Student Room
Mar 12, 2012 - 12 posts - ‎7 authors
i got a new tv in january from argos and not had a problem with it until now. The problem is that it just stays on standby and wont turn on. the ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
Hello my bush 22 inch tv is messed up Say if i go on it one day it..... it wont turn on from the power botton on the back not from the control ...
Jan 10, 2016 | Bush Televison & Video
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I turn tv on then the standby light goes green then goes to red flashing
It is a common Fault on some lcd tvs you will need a replacement switch mechanism fitted don't know the correct name for it but it can be fixed .I had exactly the same problem with my BUSH 26 inch LCD tv took it to a local independent tv shop and the owner repaired it for me it cost around £67 if my memory is correct this fault started on my TV 14 month after i bought it - 2 month out of warranty. hope this response helps
Good Luck
Eddie Hall
Nov 27, 2010 | Televison & Video
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this...
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this problem
Sep 08, 2009 | Akai LCT2785TA 27 in. LCD Television
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
BUSH LCD 27 inch
The TV is on protect mode.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
When the TV goes on protection there are only two possible reasons.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Jan 23, 2009 | Bush 5693D 24" TV
I WILL NOT BY AKIA TVS no more thay **** cant get parts
Apr 01, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Jan 06, 2008 | Bush 5693D 24" TV
27 inch Digimate LCD TV Shuts Off Automatically
have you had this probelm fixed mine just starteed to do it and its only 8 months old and I cant afford to have it fixed please help if you can thanks
Feb 04, 2007 | Digimate DGL26 Television
Televison & Video Logo
697 people viewed this question
Top Bush Televison & Video Experts
sonic boom...
sonic boom...
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
