Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
MONITOR WILL NOT WORK WHEN RE CONNECTED
I HAD INITIALLY REMOVED MY D DRIVE AS IT WAS BROKEN. I DISCONNECTED EVRYTHING TO PUT IN A NEW SONY LIGHTSCRIBE IDE TYPE DRIVE. WHEN I CONNECTED EVERYTHING BACK UP THE COMPUTER TURNS ON BUT THE MONITOR WILL NOT SWITCH ON. THE BUTTON REMAINS ORANGE. HOWEVER WHEN I DISCONNECT THE MONITOR CABLE IT GOES GREEN. WHAT CAN BE THE CAUSE OF THIS.
    President:
  • 2,692 Answers
You didn't state if you had a slot Video card , but if you do  check to see if it is down in the slot well, as you may have bumped it putting the hard driver in. Try taking it out and reinserting it, with the power off, of course.
Posted on Feb 13, 2009
I would like to install a lightscribe drive , can it be put into the hot swop carrier space witch i don't use
Yes you can add the lightscribe drive to your system as long as you have an open pay (slot) to hold it. If you have a desktop tower, then most likely you have a slot available either right under or above the current dvd/cd drive.
Just make sure your lightscribe drive has the same interface (SATA or IDE) as your current drive or you might need some cable adapters to make it work.
If your system uses IDE (little metal prongs or pins where the cable plugs into the back of the dvd/cd drive) then you want to set the jumper pin on the back of the dvd drive to CS for cable select. If there is a cable ribbon going to the current drive it will have another connection open that you can use for the new drive. Normally the cable ribbon will allow you to piggy back the two drives.
SATA is the latest technology so if your current drive is SATA, and your lightscribe is SATA then look at the two cables that go into the dvd drive already installed. There might be another set that is not being used that you can hook to the lightscribe drive. If so, hook the set to the back of the drive and into the slots on the motherboard.
May 18, 2012 | Acer Aspire M3400 PC Desktop
Hello i have a lightscribe asus drw-2014L 1T disc drive it will not burn onto lightscribe discs but ok on normal printable & dvd-rw discs can u help me with the problem
The LightScribe feature of DVD burners with this capability requires that you are using burner software that has this function. Verify that the software you are using is lightscribe compatible. The software that comes with this drive(Nero) should be lightscribe compatible. After you burn the disc you do need to fip the disc over and the re-insert into the drive so that a label can be etched into the disc. The lightscribe discs look identical on both sides so only one side you can burn info and the other side is for the label so make sure that it is inserted on the right side for each process. If you put the disc in on the wrong side the initial data burn will not work. Also sometimes burners will have issues with certain brands of discs so you may also want to try a different brand and see if that helps. And another thing that you can try is updating the drive to the latest firmware. The firmware is to the drive kind of like what Windows is to your PC. Sometimes updating this file will fix problems like this. Here is a link to the firmware of your model. http://support.asus.com/download/download.aspx?SLanguage=en-us
You can download the file and run it to update your firmware. Caution: Before running the firmware make sure it is the correct file for your drive! There are a couple of variations to your model number and this one might not be the correct one. If you install the wrong file you could damage your drive inoperable or defeat some of it's features. I hope this information is of help with your problem and thanks for using FixYa.
Aug 20, 2010 | ASUS DRW-2014L1T DVD-RAM Burner
Sony Optiarc AD-7581A 8x DVD?±RW DL Notebook IDE Drive w/LightScribe Burner is not being recognized and installed.... It shows the error 10 "device will not start" can anyone help?
Try a cold boot. Shut down the computer. Remove the battery. Unplug the power cord. Wait at least five minutes. Start up the computer. If still does not work, go to device manager --> CD/DVD drives. Uninstall the Optiarc drive. Go to Actions --> Scan for Hardware Changes, or simply reboot to reinstall the drive.
Apr 05, 2010 | Sony Optiarc AD-7581A 8x DVD?±RW DL...
Can i add lightscribe to a new laptop? just ordered it and realized it does not come with lightscribe.
The LightScribe-enabled CD/DVD disc drive contains a special laser that pumps light into this label to create whatever designs you have created. The light from the laser causes a chemical change in the dye coating that shows up as a visible point on the disc.
The best way to add this to your new computer is to buy a Lightscribe external drive that connects via a USB port.
Oct 03, 2009 | Computers & Internet
LightScribe stopped working
its not NEW its , NEW OLD STOCK (NOS)
old lightscribe, drive. the drive that prints labels on top.
NO OS STATED nor any PC stated.. wow.
Lightscribe is mostly not supported now. (read the wiki, on that it dont lie)
obviously and very hard to diagnose.
1-bad drive.
2: bad driver for drive
3: upgrated OS and it dont support this (why post lacking OS)????
4: bad media.
read this.
https://en.wikipedia.org/wiki/LightScribe
then at that bottom read HP unstable.
From HP's official site, they started phasing out Lightscribe drives in HP computers in 2011, due to "industry conditions beyond our control."
windows 8, 8.1 and w10 its not supported.
go to HP.com read what your PC supports, with the unstated
by you PC, and unstated OS
tdk and verbatium stopped making them.
not this is dead now
http://www.lightscribe.com/
some get w8 to run with W7 drivers
why not ask at HP. why here?
https://h30434.www3.hp.com/
sure NOS disks are sold rotting on selves... sure.
try google for help? see the words no support?
1st hit
http://www.wikihow.com/Use-LightScribe
Aug 19, 2017 | HP LightScribe dvd640i (DVD640I)...
HP DVD 1040i not recognised by software
Try using device manager to remove the drive, restart and Xp will load the drivers again. This fixed my errant drive. Hope it helps you too.
Dec 11, 2008 | HP LightScribe dvd640i (DVD640I)...
Reinstalling an internal disc drive
try to check the cable if it is firmly connected. try to disconnect and reconnect again the cables and make sure that it is properly connected. is this an ide or sata cable?
Jun 15, 2008 | HP LightScribe dvd640i (DVD640I)...
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
