Question about Kenmore 75620 / 75621 / 75622 / 75624 Gas Kitchen Range
Message says "unlock door", but the door is already unlocked.
We had the oven on "self-clean" and were cleaning the oven. Now that we are finished, we cannot bake. Anytime you push the "bake" button, the panel flashes a message - "unlock door.' The door is already unlocked. We already rebooted the system by shutting off the breaker, and unplugging it.
Please advise ASAP.
Thanks,
The Ramaleys.
I disconnected the micro switch that controlled the door lock.
Posted on Dec 08, 2011
  • 1,029 Answers
The selfclean latch mechanism interferes with it.Follow the instructions to unlock the latch and properly
close the door:
l Press CANCEL to erase the error code.
l Depress and hold down the DOOR LIGHT SWITCH
plunger (located on the front frame of the oven).
l Press CLEAN (not START). Latch will unlock in about 6secs
Posted on Feb 13, 2009
  • Starnley Johnwells
    Starnley Johnwells Feb 13, 2009
    hope this helps if you need further help on this pls do let me know
    Problem Solver:
  • 19 Answers
Redo the self clean, something got stuck... also, dont use the selfclean again, use easy off overnight, self cleaning sucks and uses lots of $$$$$$$.
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    Cannot unlock oven door
  • Here it is!
    Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    How do i unlock a de dietrich oven?
    In order to unlock the oven you need to perform the following:
    Jun 25, 2011 | De Dietrich Ovens
    I used the self cleaning feature. It was tricky slide the unlock over. I got it, now can't open the door.
    The Door should automatically unlock once the oven Cools down enough to Finish wiping oven out to finish cleaning.
    Nov 11, 2010 | Ovens
    Oven door after self clean cycle won't unlock
    Both the oven" ON " light and " Clean " light will flash when the clean has finished . When the " clean " light flashes , slide the latch handle to the left as far as it will go , then turn the " OVEN SET " knob to " OFF " to open the door.
    Mar 26, 2010 | GE Profile JGS968SHSS Gas Kitchen Range
    Oven door will not unlock
    Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
    MIchael Anderson
    Anderson Appliance
    (865)945-3808
    Feb 10, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Oven door remains locked after using the oven cleaning feature
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Dec 12, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
    HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
    Thank you for contacting Fixya.com
    Aug 07, 2009 | De Dietrich Ovens
    Kenmore 75620 / 75621 / 75622 / 75624 Gas Kitchen Range Logo
    358 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Mike Carew
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
