Question about Garmin Nuvi 660 GPS Receiver
660, hangs up totally after ca. 40mins use
Hi there
660T worked beautifully for ca. 2 years all over Europe. I then updated sys software from Garmin site, shortly after this (but possibly unrelated), it began to hang up completely after about 40mins use. It was on, was fully-charged and connected to power, display frozen, touchscreen inactive and nothing happening. If reset, the same hang up occured at say 20mins later, reset then 10 minutes later, and so on until I might get 2 minutes If lucky before freezing after reset. If I then leave it turned off for a long time I'll again get the 40 mins before freeze up etc as above. Sys softare is most current and I also paid for new mapping few weeks back - which I effectively can't use - had hoped installing this might help - it didn't - and cost me. Very annoyed with zero response from Garmin (probably Garmin-UK).
Can anyone email me the original sys software perhaps, might make this problem go away - it worked fine for me before. Other ideas?
Thanks
Martin.
  • 1 more comment
  • mjs6 Feb 13, 2009
    Thanks Jim
    I have V4.7 on it according to the sys info screen, but may have been corrupted I suppose. Will try reflash as you suggest. May take some time to figure out if it has worked though, I'm not driving the required ca. 40 continuous mins every day to see if it hangs-up or not. Could head off to hills tomorrow I guess and find out. Just in case, I downloaded a pile of previous versions from site. Will update you as and when. Bit of snow and brilliant sunshine in East Scotland today, thanks again from hereabouts then, regards
    Martin.
  • mjs6 Feb 16, 2009
    Question, is there a link somewhere that will tell me what each of the file types on the nuvi internal memory actually are?
    I simply went through the install procedure as normal with 4.7 (for the third time actually). I'd feel safer removing previous versions somehow. It's not clear to me if running the installer removes old stuff or modifies it (I suspect the latter - as there seems to be some sort of update file in there). If I did want to install older version, would the old install over the newer ... ? I'm not sure. I'd like to do a "clean install" if at all possible and wipe the current stuff entirely. (Other than the mapping and key evidently).
    Haven't driven far enough to test the latest 4.7 attempt yet!
    Cheers
    Martin.
  • mjs6 Apr 16, 2009
    Ok, sorry to take so long getting back to you guys - you're not forgotten. The problem is now solved. The most recent software is definitely to blame. Lost count of how many times I reinstalled V4.7 to make sure installation was ok. The 660 always developed this freezing nuisance when using version 4.7.
    As soon as I reverted to version 4.6 the problem went away entirely. Since then device has worked perfectly, including a long trip of ca. 1500 miles - without so much as a single glitch.
    Many thanks for help in finding previous s/w versions.
    Cheers
    Martin.
Nuvi 660 stopped tracking satellite
Posted on Feb 25, 2009
  • Garmin Master
  • 2,130 Answers
Hi Martin,
It sounds like a corrupted firmware update. Please go to this site:
http://gpsinformation.org/perry/nuvi/
I believe the latest firmware version for a 660 is v4.7. You can try reflashing the firmware with v4.7 or trying an earlier version. Let me know if this resolves your issue.
Also, the Nuvi can lag if you have large picture files on an inserted SD card.
- Jim
SHARCNET-USA
Posted on Feb 13, 2009
  • SHARCNET-USA
    SHARCNET-USA Feb 13, 2009
    Hi Martin,
    Always make sure you select to "safely remove" the Nuvi before pulling out the data cable. You should see that the Nuvi drive is removed from your PC's directory. Also, never turn off the unit while it's rebooting and loading the new firmware and make sure your battery is charged before doing any upgrades.
    Good idea on downloading the previous versions. Sounds beautiful there! Would love to visit there! There is a comedian that hosts a late nite show here in the USA. His name is Craig Ferguson and he's originally from Scotland. His humor is often risque, but he is hillarious to watch. :)
    Safe travels!
    - Jim
    SHARCNET- USA
  • SHARCNET-USA
    SHARCNET-USA Feb 16, 2009
    Martin,
    When you upgrade the firmware, a file called GUPDATE.GCD is added into the garmin directory. When you reboot, the contents of this file is then flashed into the GPS's non-volatile memory. Once you have rebooted, you can erase this file as its no longer needed.
    - Jim
    SHARCNET-USA
When i input details of a location and press GO all that comes up is acquiring satellites , any help would be appreciated ,thanks
The software may be out of date. To update your software you need to download and install, on your computer, the latest version of WEBUPDATER from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Next connect your satnav to your computer and run the WEBUPDATER program. It will find updates. Select all and they will be installed. Afterwards it will find optional updates. You don't need to install these unless you wish to.
I hope this solves your problem.
Also the USA version of most of the garmin satnavs do not work in Europe and the European versions do not work in the USA
Jul 21, 2011 | Garmin Nuvi 660 GPS Receiver
..comy garmin has not been
You can get details of how to update your garmin satnav at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
It's always a good idea to back up your favourites folder before you make any changes to your satnav. You can find details of how to do this at http://www.fixya.com/support/r8422587-backup_restore_favourites_garmin_nuvi
Mar 09, 2011 | Garmin GPS
Hi, deleted some important functions from my nuvi 660. How can i get the software back again. Same software which is in the navigator when u buy it from any place. Pls urgent help needed
find the software needed on the below link:
http://www8.garmin.com/support/download_details.jsp?id=1921
If the above is not what you want, then you can perform a update. I assure you that updating will help ot reinstall the deleted software.
Follow instructions on how to update your nuvi 660 from the tips posted by me on the below link: http://www.fixya.com/support/r6547054-update_garmin_nuvi_gps
I hope this helps.
Good luck.
Nov 29, 2010 | Garmin Nuvi 660 GPS Receiver
Update for Garmin nuvi 200
I just got a Garmin Nuvi 660 and cannot figure out how to charge the unit. Help!!!!
Jul 17, 2009 | Garmin Nuvi 660 GPS Receiver
How do I turn off our garmin nuvi?
Reset button behind the Antenna, press this in for a few seconds.
Use the Web-updater at Garmin, to update it too,
Jack it to a PC and run the update,
If still playing up, Use the Firmware update at Garmin for it,
(( google Garmin 660 software updates ))
Should be good then
Regards
Richard.
May 18, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 lost Europe maps
Eventually managed to speak to a man at Garmin who confirmed that it was not loading any European maps because it didn't have enough spare memory to load them all. He said that he would email me instructions for freeing up sufficient memory, the email never arrived but I decided to delet all the voice languages that were no use to me and all the other language 'help' files and tried again - it worked.
At no point did I get a 'insufficiant memory' warning, which would have been very helpful, nor is there any guidance for how much memory will be required when embarking on the update. Take note Garmin...
Feb 27, 2009 | Garmin Nuvi 660 GPS Receiver
Lost disc 660 garmin
Go to the Gamin website here and download the free webupdater software....
http://www8.garmin.com/products/webupdater
Dec 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 - how do I get FM Transmitter firmware
I believe in your location it comes as an option. transmitter is an optional module. You can browse the user manual at following link (PDF file) http://www8.garmin.com/manuals/1262_OwnersManual.pdf
You can see at 35th page, simple instructions have been given for FM transmitter settings.
If it doesn't work please contact to the Manufacturer. I couldn't find Garmin's Ireland number. However you may call UK number +44-870-8501242. Or simple you call your reseller.
Good Luck
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
566 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
