Question about Teac CD-X9 Shelf System
Remote stops working
Remote just stopped working after turning on system. Replaced battery still same problem. System work ok manually.
  • 1 more comment
  • kchem Feb 13, 2009
    I don't see anything coming from the diode. No flashes or light of any kind.
    That must be my problem
  • Mico Dukic May 11, 2010
    Glad to help you.
    Best regards,
    Mico Dukic
    Did you check if IR diode is OK on remote? You can see IR light from diode by looking through digital camera viewfinder while pressing button on remote.
The suggestion to test my remote with a digital camera found there is no output in my remote. I'll replace the remote.
Thank you for being there to help me.
Regards,
Mike Higgins
Posted on Feb 14, 2009
Sound stopped mid program cannot get it to work--replaced and cleaned battery compartment to no avail.
Try going to the BOSE webside where you can use their manuals, or videos or get in touch with their Contact Us tab
Bose Solo TV sound system Bose Product Support
Sep 05, 2015 | Bose Solo TV sound system - Black
Bose 321 dvd and remote
hello.
Clean out the battery connection inside the battery case. Incase this work disassemble your remote and find any fault connection in it. or let the repair man do it.
If the remote work change the setting press PBC mode this will change the color. or refer to the manual for changing view setting.
melnavz
Mar 31, 2008 | Bose 3 2 1 GSX System
Skytec Astra alarm system just quit working unexpectedly
STOP STOP STOP STOP STOP STOP OK OK OK OK OK OK OK OK OK OK OK OK
Oct 01, 2013 | Scytek Electronics ASTRA200 Car Alarm 1...
I have a Saab 2.2tid linear (2003). the central locking system has just stopped working completely, there was no warning to suggest its the battery in the key.. before it stopped working altogether it used...
THE SAAB 9 -3 REMOTE BATTERY HAS TO BE REPLACED AND REPROGRAMMED AT THE DEALERSHIP.THE SAAB 9 - 5 YOU COULD REPLACE REMOTE BATTERY AND REPROGRAM OR SYNCHRONIZATION BY PRESSING REMOTE KEY BUTTON UNLOCK BUTTON AT LEAST 4 TIMES TO REPROGRAM KEY REMOTE TRANSMITTER.
Mar 04, 2011 | Saab 9 3 Cars & Trucks
Battery dead.when i try to boast the car alarm goes off and i can"t turn it off without removing boaster cables
Try manually disarming the system when you hook up the battery cable. After you hook up the cable ( the siren will be going), turn ignition on, press and release valet switch one time. The siren will stop and you will be able to start the vehicle. Test the remote. If the remote is not working, and the battery is good, try reprogramming the remote. Turn ignition on, press and release valet switch one time. Press and HOLD valet switch, press lock button on remote. You will hear a confirmation chirp when the remote is programmed. Turn ignition off. Test system.
Nov 21, 2010 | Remote Start System
Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Sep 07, 2009 | Bose 3 2 1 GSX System
Remote won't work
The remote stopped working. So I changed the batteries Then remote signal's are OK But Indor Unit is not controlled by remote.
Feb 01, 2009 | LG LSC121PMA Split System Air Conditioner
JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Jan 12, 2009 | JBL (JBLRADIALWHT) Speaker System, Docking...
My bose 321 system remote control sometime works and sometime doesn't.
When we try to use the remote the red light glows which I never saw glowing when it was working properly.What could be the problem?
Jan 03, 2008 | Bose RC-18S Remote Control
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Teac CD-X9 Shelf System Logo
177 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
