Question about Dewalt 2 Position Screw Driver Kit DW920K-2
Will DeWalt charger work on 120V 50Hz?
Hello, I own DeWalt DW9118 charger, can it be runned on 50Hz frequency instead of 60hz? Some schematics would also help.
Thanks.
  • kotsa Feb 14, 2009
    OK, thanks, I just wanted to be sure. I was only 90% sure:) I guess there is a rectifier right on the input, so frequency doesn't matter that much.
    Thank you.
  • 2,176 Answers
I don't think that would be a problem, For schematics I would go to Dewaltservicenet.com and type in your model number usually in the center of the site and download a breakdown. Let me know if i can help more.
Posted on Feb 13, 2009
My relative send me a luxor tv its 50hrz..here in the philippines we use 60hrz.,is it possible and safe
is there no small slide switch at the back of the tv
10 volt difference
may need an converter to make up 10 volts
The more significant difference is that 60Hz systems usually use 110V (120V) or thereabouts for the domestic power supply, while 50Hz systems tend to use 220V, 230V etc
read this information on the 50 and 60 hrz
Difference between 50Hz and 60Hz frequency
Nov 02, 2016 | Luxor Televison & Video
I have aclock on a frigidaire microwave that is loosing time
A defective clock would be the cause, the voltage is regulated by the oven circuit board, so line voltage would rally need to be way off to affect the operation of the clock. Ranges of line voltage here in USA are 110V-120V
Jun 23, 2016 | Frigidaire Microwave Ovens
WFW70HEBW does not power
hello guys, i have the whirlpool duet white front loader and its a 120v/60hz and its not powering up when plug in. my supply system is 110v/50hz. how do i convert it to operate on the 110v/50hz?
May 15, 2014 | Whirlpool Duet White Front Load Washer -...
Have paint spraygun 60hz. want to use it in 50hz area. what can i do
Unfortunately, products are designed to work with specific voltages and frequencies. Some devices have broader ranges of voltages and frequencies because they use electronic power suppies (often called "switching power supplies") as opposed to the costlier, heavier transformer types. Nearly all devices that have motors or have a transformer will be designed to operate on either 50 or 60 hertz - not both. Use of these devices with a frequency other than what it is designed for will run too fast / too slow and will overheat to the point that it may become a fire hazard. Unlike voltages that can be easily stepped up or down with a transformer, there is no easy, inexpensive way to change frequency.
You should replace your "60Hz only" equipment with 50Hz or 50/60Hz equipment, or if a short term relocation, rent the correct 50Hz equipment instead.
I hope this helps & good luck!
Dec 13, 2012 | Garden
Can lg 50hz washing machine run on 60hz
yes but I will not good IDEA you will have phenomen transistory is electrical term in engineeering electric, you must get support via ONLINE chat or phone with LG.
you must transform the 60hz to 50hz or 50hz TO 60hz.
God bless you
Sep 30, 2012 | LG WM-1832C Front Load Washer
Hi. I have a charger for 18v Dewalt Li-Ion (dc9130 120v 60hz) and I'd like to find a circuit diagram so I might be able to convert it to use with 240v 50hz. So I probably need the diagram for the 240v one...
most chargers will fuction on 240/50 hz, look closely at the writing on the charger, it may say. I have laptop chargers and have used the overseas with no problem, that being said, you might try contacting dewalt and asking them if you can do it. Like I said, it probably already will work without doing anything. i have seen some devices (amplifiers mostly) that have a switch on the bakc to switch voltage, ( I don't recall ever seeing a switch to change line frequecny though), hope this helps a bit
Mar 10, 2011 | Dewalt Drills
Using washer with 50Hz instead of 60Hz electricity--what does it
what you need is a frequency convertor. most modern day electrical equipment is 60 hertz. motors and transformers tend to burn up if the frequency isn't correct. they generate a lot of heat which burns them up.
Oct 23, 2009 | Maytag Washer Timer - 22004015
US portastudio 2488: Can it play when connected with a transformer
The 2488mkII manual specifies that the unit can operate with either 120VAC, 60Hz (USA/Canada), 230VAC, 50Hz (U.K./Europe), 240VAC, 50Hz (Australia) so you should be fine with a transformer which can accomodate 230VAC, 50Hz).
I have actually conversed with people who have been using the 2488 in France without any power problems.
Cheers,
bd.
Sep 12, 2008 | Tascam 2488 Portastudio Multitrack...
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
Have to change power input from 120V/60Hz to 230V/50Hz
ok " check the net for plug and power converters that plug in to
Singapore receptacle
Had a set for Europe worked great
Jan 22, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Dewalt 2 Position Screw Driver Kit DW920K-2 Logo
435 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
