Question about Intel D850MV Motherboard
AGP Problem.- Intel D850MV motherboard
Regarding to Intel D850MV motherboard, I have the following problem: I have AGP card, but it seems failed, because my monitor doesn't receive any input signal from it. I removed the AGP card and I tried with a standar PCI VGA card (I haven't another AGP card), but it din't work too. Is there any jumper, in the motherboard, so I have to change in order to get to work the new PCI VGA card (I have lost my motherboard manual).
Thanks in advance, Best Regards,
Baltasar
  • Intel Master
  • 4,806 Answers
Hi there.
Try clearing the cmos AGP Problem.- Intel D850MV motherboard - fdbf23f.jpg. move the plastic jumper the alternative position, power the pc up (Nothing will happen if you have it correct, then put it back in its original position and try to boot the machine again, don't forget to clean the memory as a precaution.
Good luck and thanks for using Fixya!!
Posted on Feb 13, 2009
Hello, will my intel desktop motherboard d850mv support a Visiontek Radeon HD 3650 1GB PCIe 2.0
Your board will only support cards with an AGP slot so, the card you mentioned will not work.
Dave
Jul 08, 2011 | Intel D850MV Motherboard
D850mv sound driver required no available on intel site
1) intel.driversdown.com/Intel-drivers/s_143_1.shtml
2) www.bioticaindia.com/d850mv.html
3) www.howtodrivers.com/model552804.html
4) downloadcenter.intel.com/Detail_Desc.aspx?ProductID...
5) www.intel.com/support/.../desktop/d850mv/.../cs-013336.htm
Oct 06, 2009 | Intel D850MV Motherboard
Black screen even the power is ok!!
Your Intel D850MV motherboard uses an AGP video card. There is no onboard video (built into the motherboard). Before replacing the video card try swapping out your monitor with another. Check for display. When the system is powered on can you hear the internals running? If the swapped out monitor does not show display you'll have to replace the AGP video card. The Intel D850MV motherboard only supports AGP cards that run at 1.5volts only & can run at 2x or 4x speed. Intel shows the difference between compatible 1.5v AGP card connector & the 3.3v non compatible video card connector. Click on the Intel link to see this; http://www.intel.com/support/motherboards/desktop/sb/cs-009010.htm This next link shows a compatible AGP video card that will replace your old card; http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4116644&csid=ITD&body=MAIN#detailspecs Thanks for using fixya
Jun 04, 2009 | Intel D850MV Motherboard
VGA AGP card is Support / Not?
that the card is compatable with your version of windows is more important.
Mar 11, 2009 | Asrock P4I45GV R5 Motherboard
3d error show while running most of modern games/ AGP upgradation
It takes a hell of a computer to run decent games.
My suggestion would be to save your money, to invest in a new computer setup.
if you get a quality graphics card, for example NVidea geforce 8600 or 8800gts et,c.
your system, will not have the Memory, so you,ll then be spending on RAM.
Next step will be that, your CPU isn,t powerful enough, so that,ll be upgraded. And it,s probably already at maximum or thereabouts, for the motherboard.
I always say, if you want to play good games, get a games console.
It,s much cheaper and cost effective, you can spend £700+ to get a computer to play a game, that an xbox 360 will do for £130. Think before you spend.
Regards mike @ compurepair.
Dec 18, 2008 | Intel Desktop Board D850MV (KD850MVPAK10)...
Intel Desktop Board #D850MV
Here is the tech sheet from Intel.
The front panel connections are listed on page 72, table 46. With options on the following pages.
http://support.intel.com/support/motherboards/desktop/d850mv/sb/cs-009907.htm
Aug 30, 2008 | Intel D850MV Motherboard
Regarding graphic card query
what are u asking ? if the fx7300 iworks on the mercury pvm7 pro ? - and as much as i know the video card is AGP and the motherboard has AGP so it does
or if the fx7300 is good enough for video editing ? If so, it will do the job(almost any card does), but it wont be the best experience , specially for maya!
Aug 08, 2008 | Nvidia GeForce 6600 Graphic Card
Motherboard
Hi renjithr, the Intel D865PERL motherboard doe not use an integerated video (onboard). The D865PERL board uses an AGP add in card. AGP 8x & 4x 1.5v graphics card. If you are not receiving video, you can try removing the AGP card & clean the copper contacts by using alcohol on a cotton swab. (Allow contacts to dry). Use canned air & blow out the AGP slot. Re-seat the AGP card. If the card still does not show video than your AGP card is defective & you will need to replace it.
Click on the link below for a new AGP 8x-4x compatible video card. http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=321119&prodlist=celebros
This XFX GeForce will function in you're Intel system.
The XFX comes with a Lifetime warranty.
Have more questions, please feel free to ask.
Good Luck!
Mike
Apr 21, 2008 | Intel D865PERL Motherboard
PC got hanged after 3 beeps.
Hi, Depending on the sequence, interval and duration of the beeps, this indicates either a video card or memory problem. Try and re-seat or replace as may be applicable. you can also try cleaning the gold connectors. Good luck and kind regards.
Sep 28, 2007 | Intel D850MV Motherboard
Intel D850MV Motherboard Logo
124 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
