Question about Samsung HLN437W 43" Rear Projection HDTV
Color are not focus
Samsug tv sp43 one picture show three in different colors
  • Anonymous Mar 21, 2009
    what the f does that mean?
  • Samsung Master
  • 5,138 Answers
Replace both of your STKS they are big black ICss and ck resistors 2.7ohms 3 of them .
Posted on Feb 13, 2009
Periodic color scrambling - out of focus. Seems as though the different colors separate and get out of focus.
Ur tv is having a convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 50GX30B 50". Rear Projection...
I see three pictures blurred together in different colors almost like its out of focus but unable solve with controls
The tv have a problems know as a convergence problems,it dead.The tv convergence board require replacing 2 STK convergence ICS and some or all it resistors to solved the tv convergence board,to solved the tv convergence problems.The shop,will cost $300-350 for parts and labors.
Sep 16, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My tv is showing three different pictures in three different colors how do i solve this?
more than likely your having a color wheel issue. check the panel on your tv the color wheel is probably damaged.
Apr 14, 2010 | RCA D52W19 52" Rear Projection Television
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
52 inch rca shows picture in 3 colors will not focus
is thr convergence adjustment option still listed in the on screen menu? Let me know and I will try to assist you.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Picture problems
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
INSTRUCTIONS:
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Mar 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
No picture or sound
INSTRUCTIONS:
Feb 23, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Open Questions:
Samsung HLN437W 43" Rear Projection HDTV Logo
Henry  Thomas
Henry Thomas
