I have a 2 year old Polk PSW202 10" sub that started making distorted "barking" noises. It got worse and worse, finally unseable. Is this the driver itself? Or could it be something in the amp. It was never driven hard, but I knew that these inexpensive subs had short life spans.
Joe Kesselman < In all fairness, when I replaced the caps the sub did a pretty good job of shaking the living room, so it's not as if the thing is malignantly ill-designed like some stuff I could mention *cough* B*se *cough*, but more like an engineer made a booboo in a reasonably ok piece of gear.
Francois.
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
Cornish - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
The art of engineering is figuring out how to build something that is Just Barely good enough. Sometimes that leads to gambles which don't work out. I suspect that this is a matter of their original parts having a little leeway beyond the rated voltage, which was lost when they changed suppliers (or when the supplier made their own product more precise).
They aren't the first to dance too close to an edge; they won't be the last. At least it's a relatively easy retrofit and it doesn't seem to damage anything else.
Thanks for pointing this out. A friend has offered me a used PSW202, and I'd certainly rather know about this fix _before_ making an offer!
Was this helpful?
Yes
No
Solution #3
Phoebe - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Amazing a company would try such a stunt and think they could get away with it. Apparently, they didn't : ) John
Was this helpful?
Yes
No
Solution #4
Peter1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
The amp works ok modulo the cap problem getting fixed, so you might want to save your money, especially if you can find a decent electronics surplus store in the area.
Francois.
Was this helpful?
Yes
No
Solution #5
Green1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Thanks very much for the info, it gives me a place to start. I may just replace the amp. The cabinet is mint and the driver looks good.
Regards, Tom
Was this helpful?
Yes
No
Solution #6
Odud - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
These subs have a design flaw in the power supply: the filter capacitors, while rated at 35 volts, actually filter 36 volts at nominal wall voltage, on top of which the parts are somewhat undersized (read: high ESR) for the task. Every one I've run across has behaved exactly as yours - the barking is a function of the supply caps deteriorating over time not filtering as well as they should, thus leaving a lot of ripple on the supply rails which then gets superimposed on the signal.
Replace both power supply capacitors with 50 volt parts, and all should be well. There's not a lot of room on the board, so you might have to mount them somewhere else and run wires to the caps.
If this sounds sporty for your taste, show this post to a technical friend.
It just will not put out any sound at all. I sent it to Circuit City where I bought it. They return...
(More)
It just will not put out any sound at all. I sent it to Circuit City where I bought it. They return it with a not saying it has bad resistors and but fuse and did not give a reason why they did not fix it. I took it to Best buy they send it to their expert in Dalas and they return it un repaired saying they cant find the parts, but I ask them for a part number they did not furnished. Thank you Steve
it is possible to replace the circuit board on bu-120 infinity subwoofer, it looks like a blown...
(More)
it is possible to replace the circuit board on bu-120 infinity subwoofer, it looks like a blown capacitor.
On the circuit board the three closest resistors to R57 and R52 are apparently burned out. Three...
(More)
On the circuit board the three closest resistors to R57 and R52 are apparently burned out. Three right in a row. The application is low end to background music in a funeral home! Not a very taxing sort of thing. Can anyone tell me where to get this fixed and what happened to it?
