Question about D-Link Air Plus DP-G310 (dpg-310) Print Server
Communication between PrintServer DP-301U and HP LaserJet 1020
I have a problem with communication with Print Server DP-301U and HP LaserJet 1020 . My printer is HP LaserJet1020 (1018). The network configuration is successful, and I can see the printer in my network, and printer is ready to print, but it doesn't print. In my opinion there is not communication between PrintServer and Printer. (the USB LED diode on PrintServer is OFF, POWER and LAN Diode are ON)
  • Anonymous Apr 23, 2009
    Same problem here - no light on the LED. I don't think the 301U supports the HP 1018.
    Scholar:
  • 134 Answers
Trying turning your printer off and then back on. It happens sometimes that the print server looses the printer.
Alex
www.CAS411.com
Posted on Feb 15, 2009
My DP-301u printserver of D-link worked perfectly under windows xp. Now i upgraded all pc's to windows 7 and i can't get the printserver working again. What is the sollution? Michel Blezer
I have same problem and can't find solution. Site recomended not working. Printer allways offline. Firmware and other soft not healing. :(. Anyone help us.
Jan 17, 2010 | D-Link DP-301U (790069251979) Print Server
Printing Problem
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Aug 11, 2009 | D-Link DP 301U (DP-301U) Print Server
Using HP Laserjet P1006. Is it compatible with DP-301U
Yes. I just got mine working last night. Key is to enable print services for windows through the control panel. Without that LPR printing does not work.
Jun 08, 2009 | D-Link DP 301U (DP-301U) Print Server
USB printer HP 1020 Plus in DP-301U
Did you try using LPR mode instead? I find it works more relyable with any print server. SMB (windows network mode) is ****. I have had simalar problems with another printserver.
Apr 17, 2009 | D-Link DP-301U (790069251979) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U Print Server not continuous print from vista
    Make sure you have byte counting enabled if you are printing through LPR.
    Dec 11, 2008 | D-Link DP 301U (DP-301U) Print Server
    Dp301p+ psadmin password was forgoten
    Reset The Printserver from Backside & Gave PAssword again
    Mar 04, 2008 | D-Link DP 301U (DP-301U) Print Server
    Documents not printing
    Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
    May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
    D-Link Air Plus DP-G310 (dpg-310) Print Server Logo
    1,933 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
